Abaqus 错误信息 求解
浏览:18218 回答:1
The independent variables must be arranged in ascending order
Degree of freedom 11 and at least one of degrees of freedom 1 thru 6 must be active in the model for *dynamic temp-disp. Check the procedure and element types used in this model.
1 nodes have dof on which velocity/displacement/acceleration/base motion etc. constraints are specified simultaneously. The nodes have been identified in node set ErrNodeBCRedundantDof.
Analysis Input File Processor exited with an error.
请问 这是什么原因呀?
请问 这是什么原因呀?
没有吧,我的约束都是一个一个施加的。但还是提醒 Degree of freedom 11 and at least one of degrees of freedom 1 thru 6 must be active in the model for *dynamic temp-disp. Check the procedure and element types used in this model. 求指导。谢谢谢
