世界未解之谜
浏览:7056
请问以下这段文字表明了hepermesh中的设置出现了什么错误? *** Warning 10177 (KEY+177)
nodal rigid body and part share the same ID 2000772
nodal rigid body and part share the same ID 2000779
nodal rigid body and part share the same ID 2000780
nodal rigid body and part share the same ID 2000781
*** Error 10125 (KEY+125)
Checking PART and SECTION definition input.
PART ID 2000780 with
SECTION ID 0 does not exist.
This is PART 774 in the order of input.
expanding memory to 50179094
expanding memory to 50201000
*** Error 10387 (KEY+387)
*INITIAL_VELOCITY and *INITIAL_VELOCITY_GENERATION
cards may not be mixed
*** Error 10358 (KEY+358)
Contact definition 66 ID 66
is a SURFACE_TO_SURFACE type. Node sets
cannot be used for this type of contact.
*** Error 10133 (KEY+133)
input data failed with: 3 errors
E r r o r t e r m i n a t i o n 09/15/15 10:41:47
