请教一个简单问题。急
浏览:313850 回答:7
在BEAM188中,由于要设置变截面梁,KLIST中显示的接点坐标精确度不够 ,怎么样提取接点的精确坐标值?
请教问题要注意给别人专家分!这也是对别人工作的一种肯定!
| NX(N) | X-coordinate of node N in the active coordinate system. |
| NY(N) | Y-coordinate of node N in the active coordinate system. |
| NZ(N) | Z-coordinate of node N in the active coordinate system. |
| KX(K) | X-coordinate of keypoint K in the active coordinate system |
| KY(K) | Y-coordinate of keypoint K in the active coordinate system |
| KZ(K) | Z-coordinate of keypoint K in the active coordinate system |
偶也同意2楼看法哦。楼上的已经说的很明白了。
谢谢。
