疑难问题求助
哪位高手能回答我以下问题:
1.两个装配部件分别划分完网格之后,用节点合并法和节点刚性连接法两种方法创建有限元模型的区别,以及两者对后继分析的影响的差别?
2.在Hypermesh的分析OUT文件中出现的
Subcase Weight Compliance Weight*Comp.
1 1.000E+00 2.591115E+13 2.591115E+13
Sum of Weight*Compliance 2.591115E+13
是何意思?
3.Total # of Non-zero Stiffness Terms : 13847073
是何意思?
4.在分析中出现
WARNING # 312 FROM SUBROUTINE clcuku
In static load case 1 the compliance is negative or large 2.591115E+13
Optimization/buckling analysis cannot be performed due to possible rigid body mode
(Running out-of-core solution)
如何解决?
5.*** WARNING: PSOLID 6 is not referenced.
*** WARNING: PSOLID 12 is not referenced.
是咋回事?
今天终于看到了
