HM输出Nastran静态和模态分析文件的错误,如何解决?
做了一个简单的模态分析,想熟悉一下HM和Nastran分析的过程,但是出现很多错误,希望能帮忙解决
过程如下:
1.定义mat1:E=2.1e5,,NU=0.3,,RHO=7.8e-6
2.划分六面体单元,card image=PSOLID
3.建立边界条件(loadcols=spcs)
4. loadcols=mode:V1=0,,V2=10000,,ND=20
5.loadsteps=mode:spcs+mode,,,edit:output==displacements
6.control cards=SOL:NORMAL MODE,,,PARAM:AUTOSPC=YES,COUPMASS=-1
7.exprot==.dat
这是部分内容:
^^^ USER FATAL MESSAGE 9056 ( MODEFSRS)
^^^ NO METHOD COMMAND WAS SPECIFIED IN THE CASE CONTROL SECTION.
1 OCTOBER 10, 2006 MSC.NASTRAN 9/23/04 PAGE 1067
0 MODE SUBCASE 1
* * * * D B D I C T P R I N T * * * * SUBDMAP = PRTSUM , DMAP STATEMENT NO. 30
0 * * * * A N A L Y S I S S U M M A R Y T A B L E * * * *
0 SEID PEID PROJ VERS APRCH SEMG SEMR SEKR SELG SELR MODES DYNRED SOLLIN PVALID SOLNL LOOPID DESIGN CYCLE SENSITIVITY
0 0 1 1 ' ' T T T T T F F F 0 F -1 0 F
0SEID = SUPERELEMENT ID.
PEID = PRIMARY SUPERELEMENT ID OF IMAGE SUPERELEMENT.
PROJ = PROJECT ID NUMBER.
VERS = VERSION ID.
APRCH = BLANK FOR STRUCTURAL ANALYSIS. HEAT FOR HEAT TRANSFER ANALYSIS.
SEMG = STIFFNESS AND MASS MATRIX GENERATION STEP.
SEMR = MASS MATRIX REDUCTION STEP (INCLUDES EIGENVALUE SOLUTION FOR MODES).
SEKR = STIFFNESS MATRIX REDUCTION STEP.
SELG = LOAD MATRIX GENERATION STEP.
SELR = LOAD MATRIX REDUCTION STEP.
MODES = T (TRUE) IF NORMAL MODES OR BUCKLING MODES CALCULATED.
DYNRED = T (TRUE) MEANS GENERALIZED DYNAMIC AND/OR COMPONENT MODE REDUCTION PERFORMED.
SOLLIN = T (TRUE) IF LINEAR SOLUTION EXISTS IN DATABASE.
PVALID = P-DISTRIBUTION ID OF P-VALUE FOR P-ELEMENTS
LOOPID = THE LAST LOOPID VALUE USED IN THE NONLINEAR ANALYSIS. USEFUL FOR RESTARTS.
SOLNL = T (TRUE) IF NONLINEAR SOLUTION EXISTS IN DATABASE.
DESIGN CYCLE = THE LAST DESIGN CYCLE (ONLY VALID IN OPTIMIZATION).
SENSITIVITY = SENSITIVITY MATRIX GENERATION FLAG.
No PARAM values were set in the Control File.
1 * * * END OF JOB * * *
