『求助』谐响应分析时出现错误提示,求高人指点
浏览:167755 回答:3
我做谐响应分析,出现这样的错误提示
no stiffness matrix for element 241 found on the emate file.probably due to missing EMATEWRITE,YES in the first load step
241单元是beam188单元,单元属性中也打开应力应变计算选项的
不知道他的提示中EMATEWRITE选项在哪儿设置,望高人指点!
Richard
满意请给分!
2007年6月1日
Richard
直接用命令流试一下!
2007年5月30日
Richard
EMATWRITE, Key
Forces the writing of all the element matrices to File.EMAT.
Key
Write key:
YES
Forces the writing of the element matrices to File.EMAT even if not normally done.
NO
Element matrices are written only if required (default).
Notes
Forces the program to write the File.EMAT and is used if you intend to issue a subsequent PSOLVE that requires File.EMAT as a prerequisite or if you plan to follow the initial load step with a subsequent inertia relief calculation using the IRLF command.
This command is also valid in PREP7.
Menu Paths
This command cannot be accessed from a menu.
2007年5月29日
