『求助』大侠帮帮我这个初学者啊,感激不尽啊,
浏览:126158 回答:4
运行求解器optistruct,出现error,不能运行,出现下面的问题
如何解决啊,我初次使用hypermesh啊,就遇到这样的问题.各位帮忙啊
*** OptiStruct defaults set from:
global config file: D:\Altair\hw7.0/optistruct/optistruct.cfg
ERROR # 16 FROM SUBROUTINE renum
CQUAD4 element 78328 references a missing or invalid property.
***** FATAL INPUT DATA ERROR *****
CQUAD4 element 78330 references a missing or invalid property.
CQUAD4 element 78333 references a missing or invalid property.
CQUAD4 element 78334 references a missing or invalid property.
CQUAD4 element 78337 references a missing or invalid property.
CQUAD4 element 78338 references a missing or invalid property.
CQUAD4 element 78339 references a missing or invalid property.
CQUAD4 element 78343 references a missing or invalid property.
CQUAD4 element 78346 references a missing or invalid property.
CQUAD4 element 78347 references a missing or invalid property.
CQUAD4 element 78348 references a missing or invalid property.
CQUAD4 element 78350 references a missing or invalid property.
CQUAD4 element 78351 references a missing or invalid property.
CQUAD4 element 78352 references a missing or invalid property.
CQUAD4 element 78354 references a missing or invalid property.
CTRIA3 element 78327 references a missing or invalid property.
CTRIA3 element 78329 references a missing or invalid property.
CTRIA3 element 78331 references a missing or invalid property.
CTRIA3 element 78332 references a missing or invalid property.
CTRIA3 element 78335 references a missing or invalid property.
CTRIA3 element 78336 references a missing or invalid property.
CTRIA3 element 78340 references a missing or invalid property.
CTRIA3 element 78341 references a missing or invalid property.
CTRIA3 element 78342 references a missing or invalid property.
CTRIA3 element 78344 references a missing or invalid property.
CTRIA3 element 78345 references a missing or invalid property.
CTRIA3 element 78349 references a missing or invalid property.
CTRIA3 element 78353 references a missing or invalid property.
CTRIA3 element 78355 references a missing or invalid property.
ERROR # 14 FROM SUBROUTINE renum
29 errors found in the input data.
***** FATAL ERROR ENCOUNTERED *****
(4)
fantasy
嗯,建议版主建立一个置顶的帖子,将大家平时工作中所犯的错误收集起来,避免大家以后做分析时犯同样的错误,即使犯了,查一下也就迎刃而解了。
2008年3月23日
lask
学习中。。。。。。。。。。。。。。
2007年9月18日
sunny
初学时经常遇到这类问题,主要是你定义了材料属性后并没有将该属性赋予划分的单元,在collectors中用update功能将属性赋予单元就OK了。
2007年9月10日
winken
从你给出的信息文件看,是你的单元属性定义有问题,可能是你的模型使用了不同的单元来定义,建议你熟悉一下OPTISTRUCT的单元类型和相关资料
2007年9月8日
