求助:ANSYS运行时出现下面的字样
浏览:121836 回答:1
Product: ANSYS Multiphysics (feature 'ane3fl')
Checkout failed for the above product.
FLEXlm error message:
Cannot connect to license server(-15,10:10061 "WinSock:Connection refused")
Servers/license files searched:
1055@XXXX-PC
C:\PROGRA\ANSYS\SHARED\LIGENS\license.dat
(For additional licensing debug details, set the ANS_FLEXLM_DEBUG
environment variable to '1' before running this product. For
maximum licensing debug details, set this environment variable to
'2'.)
我想应该是license问题,但不知道怎么解决,请大家帮助一下,谢谢
应该是license没装好,一个要注意的是计算机名,
第二是安装后打开FLEXLM LMTOOLS UTILITYS
LMGRD.EXE
LICENSE.DAT
DEBUG LOG
三个文件的位置设置好就可以啦
2008年3月31日
