bolt.pdf
2009-06-25 评论:4 下载:15
下载
大小:1.39MB
在ansys里建螺栓模型的方法
The "Solid Bolt" option models a
solid bolt with pretension, "Bolt with spiders" option models the bolt shank as a beam and the head and nut
with spiders of beam elements with large stiffness, "Bolt with RBE3 command" models the bolt shank with
beam elements and uses RBE3 elements to represent the head节选段落二:
Bolt Wizard Main Menu Figure 4. Solid Bolt Menu
Figure 5.节选段落三:
Conclusion
A Bolt Modeling Wizard was developed, using Tcl/Tk and APDL. This wizard is interfaced with Ansys
using UIDL. Features of this wizard include four different types of bolt simulation, viz. Solid bolt, bolt with
spiders, bolt with RBE3 command and bolt with shell elements.
Figure 5.节选段落三:
Conclusion
查看更多评论 >
