Ensight.pdf
Ensight-部分使用教程
Using EDEM with EnSight
Copyrights
Copyright © 2002-2008 DEM Solutions. All rights reserved.
Information in this document is subject to change without notice. The software described in this
document is furnished under a license agreement or nondisclosure agreement.节选段落二:
Select File > Export > EnSight Case Gold.
3. Under Functions to Write, select the required fluid parameters, such as Velocity
Magnitude (Fluid).
4. Click Write to save the EnSight files.
EDEM
1. Select the Analyst then open the relevant EDEM file.
2.节选段落三:
From EnSight, select File > Open then navigate to the .encas file you exported
from Fluent. Click OK.
2. Select File > Open again then navigate to the .case file you exported from
EDEM using the default values in EnSight.
Copyrights
Magnitude (Fluid).
EDEM
2.节选段落三:
