fluent理论手册.pdf
2021-04-12 评论:1 下载:13
下载
大小:5.19MB
fluent理论手册
physical models used by ANSYS FLUENT
to simulate the performance of heat exchangers.
• Chapter 7: Species Transport and Finite-Rate Chemistry, describes the finite-rate
chemistry models in ANSYS FLUENT.
节选段落二:
January 29, 2009 UTM-1
Using This Manual
• Chapter 10: Partially Premixed Combustion, describes the partially premixed com-
bustion model.
• Chapter 11: Composition PDF Transport, describes the composition PDF transport
model.
• Chapter 12: Engine Ignition, describes the engine ignition models available
节选段落三:
Figures 1.6.1 and 1.6.2 show examples of compressible flows computed
using ANSYS FLUENT.
(1条)
赞👍
