Hypermesh与abaqus接口实例.doc
2021-06-17 评论:2 下载:19
- 技术邻 >
- CAE仿真 >
- 前后处理 ,
- HyperWorks ,
- Abaqus
下载
大小:221.00KB
Hypermesh和Abaqus的接口分析实例(三维接触分析)
In this tutorial, you will learn how to:
· Load the Abaqus user profile and model
· Define the material and properties and assign them to a component
· View the *SOLID SECTION for solid elements
· Define the *SPRING properties and create a component collector for it
·节选段落二:
Create the *SPRING1 element
· Assign a property to the selected elements
Step 1: Load the Abaqus user profile and model
A set of standard user profiles is included in the HyperMesh installation. 节选段落三:
Steps 21-22: Export the database to an Abaqus input file
The data currently stored in the database must be output to an Abaqus .inp file for use with the Abaqus solver. The .inp file can then be used to perform the analysis using Abaqus outside of HyperMesh.
Step 21: Export the .inp file
1.
·节选段落二:
1.
