usermat程序入门讲解.pdf
2021-09-02 评论:1 下载:13
下载
大小:43.08KB
usermat程序入门讲解(很基础,新手强烈建议
USER MATERIAL ROUTINE (USERMAT)........................................................................ 3
3.
节选段落二:
The input parameters for the USERMAT subroutine is
defined by command TB,USER.
This report provides guidelines on how to write a user material routine using USERMAT.
2.
节选段落三:
If the state variables are used in the USERMAT routine, the number
of state variables must be defined by the command TB, STATE. For every Newton-Raphson
iteration, USERMAT is called at every material integration point.
(1条)
