simufact.forming_exit_codes_11.0_en.pdf
2013-03-10 评论:8 下载:31
下载
大小:3.33MB
以前,对于simufact的错误总找不到原因,看了这个文档让我明白的错误所在!
codes
2 Exit codes
simufact.forming Exit codes Exit 7
节选段落二:
Call your local Simufact Engineering GmbH representative.
simufact.forming Exit codes Exit 15
5
2.3. Exit 15
Material file for the flow curve description could not be opened from the data base (*.mat, *.dat).
2.3.1.
节选段落三:
\simufact\forming\10.0\sf-
Marc\AF_flowmat) or local directory.
2.3.3. Solution
Copy file to local or flow curve directory.
2.4. Exit 28
Contact body moves away from bottom dead center, load case cannot be calculated.
2.4.1.
(6条)
<br/>下来看看
支持了,我的simufact老是mesh failed 真奇怪
评论 2 点赞
回复
您好,请问您mesh failed这一问题您怎么解决的?
回复
先下来看看
查看更多评论 >
