Maxwell分析后处理经验总结.pdf
maxwell技巧
This value matches the value obtain using the finite elements
3.计算直流分析通过导体截面的电流
Calculate Resistance
– Select the menu item Maxwell 3D → Fields → Calculator
– In Field Calculator window:
1. Select Input > Quantity > J
2. Select Vector > Scal? > ScalarZ
3.节选段落二:
Trace
5.绘制沿着线 path 的磁场强度结果曲线
Plot Mag_H along a Line
– Select the menu item Maxwell 3D → Results → Create Field Reports → Rectangular Plot
– In Report window.
1.节选段落三:
SlugHeight
– Select the menu item Maxwell 3D → Results → Create Magnetostatic Report → Rectangular
Plot
– In Report window,
1. Parameter: Force1
2. Primary Sweep: SlugHeight
3. X : Default
4. Category: Output Variables
5. Quantity: MagForceSlug
6.
3.计算直流分析通过导体截面的电流
3.节选段落二:
Trace
– In Report window.
1.节选段落三:
SlugHeight
Plot
– In Report window,
3. X : Default
6.
