AspenHYSYSV7_2-Tutorial.pdf
ASPEN HYSYS帮助文档
Create a unit set.
2. Choose a property package.
3. Select the components.
4. Define the reaction.
5. Create and specify the feed streams.
6. Install and define the Mixer and
Reactor.
7.节选段落二:
From the list, select USGPM.
7. The new unit set is now defined. Close the Session
Preferences property view.
Figure 3.5
3-6
Chemicals Tutorial 3-7
3.2.3 Building the Simulation
1. Click the New Case icon.
The Simulation Basis Manager appears.
2. The next task is to create a Fluid Package.节选段落三:
........................2-1
2.1 Introduction .................................................... 2-2
2.2 Steady State Simulation.................................... 2-4
2.3 Dynamic Simulation.......................................2-130
3 Chemicals Tutorial...........................................
Create a unit set.
Reactor.
7.节选段落二:
Figure 3.5
3-6
