maxwell3D教程.pdf
见附件
Creating the Geometry Model 3-3
Getting Started with Maxwell: Transient Problem
To move the box into position:
1 Select the box object previously created (for example, click the respec-
tive name in the history tree window).
2 Select Edit>Arrange>Move.
3 Enter (0, 0, 0) in the (X, Y, Z) fields as节选段落二:
Select the folder where you want to save the external circuit file.
d. Type trans_circ.sph in the File name box.
e.节选段落三:
Click Maxwell>Excitations>External Circuit>Edit External Circuit.
The Edit External Circuit dialog box appears.
b. Click Import Circuit.
The Select File dialog box appears.
c. Set Designer Net List Files (*.sph) from the Files of type pull-down
list.
d.
e.节选段落三:
list.
d.
查看更多评论 >
