ANSYS_CFD管道流体分析经典算例_Fluid.doc
2015-12-02 下载:62
下载
大小:943.00KB
          Type 1 in the Element type reference number.
         Click on Flotran CFD and select 2D Flotran 141. Click OK. Close the Element types window.
         So now we have selected Element type 1 to be solved using Flotran, the computational fluid dynamics portion of ANSYS.
节选段落二:
Go to the ANSYS Main Menu
Click Preprocessor>Material Props>Material Models. The following window will appear
As displayed, choose CFD>Density. The following window appears.
Fill in 1.23 to set the density of Air. Click OK.
Now choose CFD>Viscosity.
节选段落三:
(VX=VY=0 for all sides)
Once they have been applied, the pipe will look like this:
         Go to Main Menu>Preprocessor>Loads>Define Loads>Apply>Fluid  CFD>Pressure DOF>On Lines.
         Pick the outlet line.
