OS-T:2000 Design Concept for a Structral C-Clip.pdf
2019-09-09 下载:5
下载
大小:674.06KB
拓扑优化Altair 官方教程 C型架子概念设计。
OS-T: 2000 Design Concept for a Structural C-Clip
In this tutorial you will perform a topology optimization on a model to create a new topology
for the structure, removing any unnecessary material. The resulting structure is lighter and
satisfies all design constraints.
节选段落二:
Create a force at the top of the opening of the c-clip.
a. Using the nodes selector, select the node at the top of the opening of the clip.
b. In the magnitude= field, enter 100 .
c. Set the vector selector to y-axis.
d. Click create.
Figure 4.
4.
节选段落三:
Create a force at the bottom of the opening of the c-clip.
a. Using the nodes selector, select the node at the bottom of the opening of the clip.
b. In the magnitude= field, enter -100 .
d. Click create.
Figure 5.
5.
