求助,我的ANsys11.0单元模型中找不到structural solid /Triangle 6node 2模块
浏览:91938 回答:6
我的ANsys11.0单元模型中找不到structural solid /Triangle 6node 2模块,是下载的软件不全,还是设置问题,如果是不全,又如何添加单元库文件呢?求教各位大侠啦!不胜感激!
(6)
for1314
嗯,很详细,看来help很有用。
2011年8月5日
非常感谢班主,终于弄明白啦,谢谢!
2008年8月30日
feifei
11.0 plane183是Triangle 6node
PLANE183
2-D 8-Node or 6-Node Structural Solid
MP ME ST PR PRN DS DSS <> <> <> <> PP VT
Product Restrictions
PLANE183 Element Description
PLANE183 is a higher order 2-D, 8-node or 6-node element. PLANE183 has quadratic displacement behavior and is well suited to modeling irregular meshes (such as those produced by various CAD/CAM systems).
This element is defined by 8 nodes or 6-nodes having two degrees of freedom at each node: translations in the nodal x and y directions. The element may be used as a plane element (plane stress, plane strain and generalized plane strain) or as an axisymmetric element. This element has plasticity, hyperelasticity, creep, stress stiffening, large deflection, and large strain capabilities. It also has mixed formulation capability for simulating deformations of nearly incompressible elastoplastic materials, and fully incompressible hyperelastic materials. Initial stress import is supported. Various printout options are also available. See PLANE183 in the Theory Reference for ANSYS and ANSYS Workbench for more details about this element.
2008年8月30日
谢谢各位啦,不过还是不行。
2楼,9.0里也有8node183的,我的11.0跟别的版本对过,就是没有structural solid /Triangle 6node 2单元。在电驴上重下了个11.0sp1版,装了,也没有这个单元,晕得很。
3楼,我您说的,我试过啦,还是找不到这个单元,是不是软件没装全啊?
还是谢谢各位关心啦!
2008年8月27日
邹正刚
在 Preference 中,选择 Structure,然后再试试。
2008年8月26日
feifei
你是想做断裂分析吧 ,11.0把单元号 变了好像是183
2008年8月26日
