剖分时出现的错误
浏览:119220 回答:3
第一种
poorly shaped facets in surface mesh. Either:
(1) Mesh surfaces with tris & modify mesh control or Smartsize settings to get good tri mesh, then Vmesh again; AND/OR
(2) Use alternate mesher by setting "MOPT,VMESH,ALTE".
第二种
Volume 375 cannot be meshed. 3 location(s) found where non-adjacent boundary triangles touch. Geometry configuration may not be valid or smaller element size definition may be required.
我在划分网格时老是出现这样的错误,也不知道是尺寸给的不合适还是别的原因。另外我想问一下那第个里面的代号3表示的是什么意思。恳请知道的同行给予解答,万分感谢!
第二种
