干涉深度
浏览:95300 回答:1
请问干涉深度是什么意思,数值应该怎样设置
chenjinfang
Remeshing will be triggered when the an element edge of meshed body has been penetrated by the master object by a specified amount. The penetration distance is determined differently depending on whether the specified distance is positive or negative.
数值设置小了,模拟结果更精确,但是计算时间会更长!
2009年6月25日
