求助ANSYA/LSDYNA做爆炸分析时K文件的问题
浏览:111122
求助:急请高手指教,感激不尽!
我用 LS-dyna做钢筋混凝土板的爆炸分析,改好K文件,用LS-dyn Solver 求解时遇到以下问题: Date: 02/24/2009 Time: 22:51:22
___________________________________________________
| Livermore Software Technology Corporation |
| 7374 Las Positas Road |
| Livermore, CA 94551 |
| Tel: (925) 449-2500 Fax: (925) 449-2507 |
| www.lstc.com |
|_________________________________________________|
| LS-DYNA, A Program for Nonlinear Dynamic |
| Analysis of Structures in Three Dimensions |
| Version: 970 Date: 01/10/2005 |
| Revision: 5434a Time: 18:01:01 |
| Features enabled in this version: |
| ANSYS Database format |
| Shared Memory Parallel |
| Licensed to: |
| Platform : |
| OS Level : WINDOWS XP |
| Hostname : 606-49038c6a3f2 |
| Precision : Single precision (I4R4) |
| Unauthorized use infringes LSTC copyrights |
Input file: C:\DOCUME~1\xiaqian\桌面\5cmAl.k
The native file format : 32-bit small endian
Memory size from command line: 200000000
expanding memory to 200000000
******** notice ******** notice ******** notice ********
* This is the LS-DYNA Explicit Finite Element code. *
* Neither LSTC nor the authors assume any responsibility for *
* the validity, accuracy, or applicability of any results *
* obtained from this system. The user must verify his own *
* results. *
* LSTC endeavors to make the LS-DYNA code as complete, *
* accurate and easy to use as possible. *
* Suggestions and comments are welcomed. Please report any *
* errors encountered in either the documentation or results *
* immediately to LSTC through your site focus. *
* Copyright (C) 1990-2005 *
* by Livermore Software Technology Corp. (LSTC) *
* All rights reserved *
contracting memory to 2456376
expanding memory to 4892752
expanding memory to 8813488
expanding memory to 19804180
expanding memory to 19834180
expanding memory to 19894180
expanding memory to 19920792
expanding memory to 19998152
expanding memory to 20020759
expanding memory to 27209405
expanding memory to 27861861
expanding memory to 28514317
expanding memory to 29166773
expanding memory to 40112465
expanding memory to 40764921
LS-DYNA will perform a structural only analysis
RC SLAB FOR 10KG CHARGE WITH 5CM FOAM
ls-dyna (version 970 ) date 01/10/2005
expanding memory to 3159
expanding memory to 25800
expanding memory to 7344773
expanding memory to 26699430
expanding memory to 27307504
expanding memory to 30956068
contracting memory to 26772790
expanding memory to 43402928
expanding memory to 43404949
contracting memory to 43404928
expanding memory to 43445708
expanding memory to 55731826
expanding memory to 73588362
expanding memory to 147471994
expanding memory to 147990707
expanding memory to 148090043
expanding memory to 154968461
contracting memory to 153283116
expanding memory to 155241021
contracting memory to 153432423
expanding memory to 153939177
contracting memory to 153939177
expanding memory to 153939257
contracting memory to 153939257
expanding memory to 155896625
expanding memory to 155896732
expanding memory to 155896738
expanding memory to 165286492
expanding memory to 288930302
*** Error Memory is set 88930302 words short
increase the memory size.
Current memory size 200000000
T i m i n g i n f o r m a t i o n
CPU(seconds) %CPU Clock(seconds) %Clock
Initialization ....... 0.0000E+00 0.00 0.0000E+00 0.00
Element processing ... 0.0000E+00 0.00 0.0000E+00 0.00
Binary databases ..... 0.0000E+00 0.00 0.0000E+00 0.00
ASCII database ....... 0.0000E+00 0.00 0.0000E+00 0.00
Contact algorithm .... 0.0000E+00 0.00 0.0000E+00 0.00
Contact entities ..... 0.0000E+00 0.00 0.0000E+00 0.00
Rigid bodies ......... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Nonlinear ... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Lin. Alg. ... 0.0000E+00 0.00 0.0000E+00 0.00
T o t a l s 0.0000E+00 0.00 0.0000E+00 0.00
Problem time = 0.0000E+00
Problem cycle = 0
Total CPU time = 0 seconds ( 0 hours 0 minutes 0 seconds)
CPU time per zone cycle = 0 nanoseconds
Clock time per zone cycle= 0 nanoseconds
Number of CPU's 1
NLQ used/max 96/ 96
Start time 02/24/2009 22:51:22
End time 02/24/2009 22:52:16
Elapsed time 54 seconds ( 0 hours 0 minutes 54 seconds)
E r r o r t e r m i n a t i o n
我在customization preferences 把memory(words) 改为300000000 出现以下错误:
Date: 02/24/2009 Time: 22:55:11
| www.lstc.com |
| Licensed to: |
| Platform : |
Memory size from command line: 300000000
expanding memory to 300000000
*** Error LS-DYNA failed to allocate 300000000 words of memory.
Please use the memory option on the execute line.
Problem cycle = 0
Number of CPU's 0
NLQ used/max 96/ 96
Start time 02/24/2009 22:55:11
End time 02/24/2009 22:55:11
Elapsed time 0 seconds ( 0 hours 0 minutes 0 seconds)
我再改大customization preferences 的memory(words)数值 也是一样的
Error LS-DYNA failed to allocate的错误,我改成其他的数值要么是Error Memory is set ********* words short increase the memory size的错误 要么是Error LS-DYNA failed to allocate 的错误,改到很大时干脆出现* Error Memory is set 2456376 words short
Current memory size 0 这样的错误
令我郁闷的是一样的K文件在师兄的电脑上可以算(没有改memory值,用的K文件里默认的300000000),在我的电脑上就不行,师兄电脑2G内存,我的4G
实在没法了,请教各位高手,不然我的工作没法继续了,谢谢!期待您的答复!
