新加材料的问题和相关定义
浏览:142208 回答:4
新加材料的问题和相关定义
哪位知道,线性硬化模型,幂指数硬化模型,分段线性硬化模型,都是什么意思?我在新加材料的时候,根据这三种模型,需要的参数也是不一样,很是迷糊,在材料网站上查到下面数据,只是不清楚哪些DYNAFORM里面需要,还请指教?
Titanium Ti-6Al-4V (Grade 5), STATitanium Ti-6Al-4V (Grade 5), STA
Physical Properties
Metric
English
Comments
Density
4.43 g/cc
0.160 lb/in³
Mechanical Properties
Metric
English
Comments
Hardness, Brinell
379
379
Estimated from Rockwell C.
Hardness, Knoop
414
414
Hardness, Rockwell C
41
41
Hardness, Vickers
396
396
Tensile Strength, Ultimate
1170 MPa
170000 psi
Tensile Strength, Yield
1100 MPa
160000 psi
Elongation at Break
10.0 %
10.0 %
Modulus of Elasticity
114 GPa
16500 ksi
Average of tension and compression
Compressive Yield Strength
1070 MPa
155000 psi
Notched Tensile Strength
1550 MPa
225000 psi
Kt (stress concentration factor) = 6.7
Ultimate Bearing Strength
2140 MPa
310000 psi
e/D = 2
Bearing Yield Strength
1790 MPa
260000 psi
e/D = 2
Poissons Ratio
0.330
0.330
Charpy Impact
23.0 J
17.0 ft-lb
V-notch
Fatigue Strength
160 MPa
@# of Cycles 1.00e+7
23200 psi
Kt (stress concentration factor) = 3.3
700 MPa
102000 psi
Unnotched
Fracture Toughness
43.0 MPa-m½
39.1 ksi-in½
Shear Modulus
44.0 GPa
6380 ksi
Shear Strength
760 MPa
110000 psi
Ultimate shear strength
Electrical Properties
Metric
English
Comments
Electrical Resistivity
0.000178 ohm-cm
0.000178 ohm-cm
Magnetic Permeability
1.00005
1.00005
at 1.6 kA/m
Magnetic Susceptibility
0.00000330
0.00000330
cgs/g
Thermal Properties
Metric
English
Comments
CTE, linear
8.60 µm/m-°C
@Temperature 20.0 - 100 °C
4.78 µin/in-°F
@Temperature 68.0 - 212 °F
9.20 µm/m-°C
@Temperature 20.0 - 315 °C
5.11 µin/in-°F
@Temperature 68.0 - 599 °F
average
9.70 µm/m-°C
@Temperature 20.0 - 650 °C
5.39 µin/in-°F
@Temperature 68.0 - 1200 °F
average
Specific Heat Capacity
0.5263 J/g-°C
0.1258 BTU/lb-°F
Thermal Conductivity
6.70 W/m-K
46.5 BTU-in/hr-ft²-°F
Melting Point
1604 - 1660 °C
2919 - 3020 °F
Solidus
1604 °C
2919 °F
Liquidus
1660 °C
3020 °F
Beta Transus
980 °C
1800 °F
(4)
用106号材料吧,考虑热效应的。
2009年5月15日
brian_zhang
线性硬化:在塑性阶段加工硬化成线性状态,需要硬化模量K值。
指数硬化:在塑性阶段的加工硬化成非线性状态,需要硬化指数n值,有时也需要K值。公式为K(E0+E)square(n).36号材料的2号硬化模式就是这种方法。
分断线性硬化:跟线性硬化差不多,只是将一条线段分成几条斜率不同的线段连接起来而已。24号材料用的这种模型。
从你给出的材料参数看,如果你要做冲压,虽然参数很多,但是有用的不多,选36号材料的话能用到密度,杨氏模量,泊松比,屈服强度,但是还缺少厚向异性系数r值。
2009年5月14日
王毅
材料参数的定义,有多个帖子了,你搜一下吧,呵呵~~
2009年5月12日
mrsamwalt_1985
应该是不同的模型对应的本构方程也是不一样的,我也不是太清楚,你查一查材料硬化模型的几种分类,或者再请教一下别的高手吧,帮你顶上去。
2009年5月11日
