请教轴承的分析
浏览:74730 回答:2
/COM,
/COM,Preferences for GUI filtering have been set to display:
/COM, Structural
/COM, Thermal
/filname,CAD-3-0,1
!设置单元和材料属性
/PREP7
ET,1,SOLID70
mp,kxx,1,66.6
!建模
/Prep7
k,1,40.00000,410.0000,0.000000
k,2,40.00000,384.6791,0.000000
k,3,135.0000,362.7319,0.000000
k,4,230.0000,384.6791,0.000000
k,5,230.0000,410.0000,0.000000
k,6,0.000000,335.0000,0.000000
k,7,0.000000,280.0000,0.000000
k,8,134.7500,280.0000,0.000000
k,9,134.7500,309.8622,0.000000
k,10,109.7500,309.8622,0.000000
k,11,31.81165,325.0000,0.000000
k,12,33.93722,335.0000,0.000000
k,13,135.2500,280.0000,0.000000
k,14,135.2500,309.8622,0.000000
k,15,160.2500,309.8622,0.000000
k,16,238.1883,325.0000,0.000000
k,17,236.0628,335.0000,0.000000
k,18,270.0000,335.0000,0.000000
k,19,270.0000,280.0000,0.000000
k,20,38.04900,354.3444,0.000000
k,21,111.4101,338.7511,0.000000
k,22,105.4472,310.6980,0.000000
k,23,231.9510,354.3444,0.000000
k,24,158.5899,338.7511,0.000000
k,25,164.5528,310.6980,0.000000
k,26,0,0,0
k,27,270,0,0
!点生成线
l,1,2
l,2,3
l,3,4
l,4,5
l,5,1
l,6,7
l,7,8
l,8,9
l,9,10
l,10,11
l,11,12
l,12,6
l,13,14
l,14,15
l,15,16
l,16,17
l,17,18
l,18,19
l,19,13
!线生成面
al,1,2,3,4,5
al,6,7,8,9,10,11,12,
al,13,14,15,16,17,18,19
!划分单元
/Prep7
!外圈
lsel,s,,,2,3,1
LESIZE,all, , ,10, , , , ,1
lsel,s,,,5
LESIZE,all, , ,20, , , , ,1
lsel,s,,,1
lsel,a,,,4
LESIZE,all, , ,3, , , , ,1
lsel,s,,,10
lsel,a,,,15
lsel,s,,,6
lsel,a,,,8
LESIZE,all, , ,4, , , , ,1
lsel,s,,,12
lsel,a,,,17
lsel,s,,,11
lsel,a,,,16
LESIZE,all, , ,1, , , , ,1
lsel,s,,,7
lsel,a,,,19
LESIZE,all, , ,15, , , , ,1
lsel,s,,,9
lsel,a,,,14
LESIZE,all, , ,2, , , , ,1
lsel,s,,,8
lsel,a,,,13
!绕26-27转生面体
vrotat,1,2,3,,,,26,27,,
lsel,s,,,25,29,1
LESIZE,all, , ,30, , , , ,1
lsel,s,,,63,67,1
lsel,s,,,101,105,1
lsel,s,,,134,138,1
lsel,s,,,134,138,1
lsel,s,,,75,81,1
lsel,s,,,89,95,1
lsel,s,,,113,119,1
lsel,s,,,127,133,1
lsel,s,,,139,152,1
lsel,s,,,37,43,1
lsel,s,,,51,57,1
vsweep,1
vsweep,2
vsweep,3
vsweep,4
vsweep,5
vsweep,6
vsweep,7
vsweep,8
vsweep,9
vsweep,10
vsweep,11
vsweep,12
!定义工作平面
kwplan,1,20,21,11
!旋转工作平面
wprota,,,90
!定义局部坐标系
cswpla,11,1
!在工作面上生成锥体
con4,,,30,28.6798,75
定义工作平面
kwplan,1,23,24,11
!旋转工作面
wprota,,,90
!定义局部坐标系
cswpla,12,1
!在工作面上生成锥体
!压缩定义的项目编码
numcmp,all
!滚子
lsel,s,,,153,160,1
lsel,a,,,163,170,1
LESIZE,all, , ,5, , , , ,1
lsel,s,,,161,162,1
lsel,a,,,171,172,1
vsweep,13
vsweep,14
!坐标系
csys,0
k,109,0,0,100
!三个关键点定义局部坐标系的
cskp,13,1,26,7,109,1,1
!激活先前定义的坐标系
csys,13
!滚子
vgen,30,13,14,1,0,12,0,,0,0
!生成接触对
!滚子与滚道
ALLSEL,ALL
/COM, CONTACT PAIR CREATION - START
CM,_NODECM,NODE
CM,_ELEMCM,ELEM
CM,_KPCM,KP
CM,_LINECM,LINE
CM,_AREACM,AREA
CM,_VOLUCM,VOLU
/GSAV,cwz,gsav,,temp
!摩擦系数
MP,MU,1,0.1
MAT,1
R,3
REAL,3
ET,3,170
ET,4,174
KEYOPT,4,9,1
KEYOPT,4,10,1
R,3,
RMORE,
RMORE,,0
RMORE,0
! Generate the target surface
!选择面
ASEL,S,,,5,71,22
CM,_TARGET,AREA
TYPE,3
NSLA,S,1
ESLN,S,0
ESURF
CMSEL,S,_ELEMCM
!Generate the contact surface
NSEL,NONE
csys,13
nsel,s,loc,y,-2,2
nsel,a,loc,y,10,14
nsel,a,loc,y,22,26
nsel,a,loc,y,34,38
nsel,a,loc,y,46,50
nsel,a,loc,y,58,62
nsel,a,loc,y,70,74
nsel,a,loc,y,82,86
nsel,a,loc,y,94,98
nsel,a,loc,y,106,110
nsel,a,loc,y,118,122
nsel,a,loc,y,130,134
nsel,a,loc,y,142,146
nsel,a,loc,y,154,158
nsel,a,loc,y,166,170
nsel,a,loc,y,178,182
nsel,a,loc,y,190,194
nsel,a,loc,y,202,206
nsel,a,loc,y,214,218
nsel,a,loc,y,226,230
nsel,a,loc,y,238,242
nsel,a,loc,y,250,254
nsel,a,loc,y,262,266
nsel,a,loc,y,274,278
nsel,a,loc,y,286,290
nsel,a,loc,y,298,302
nsel,a,loc,y,310,314
nsel,a,loc,y,322,326
nsel,a,loc,y,334,338
nsel,a,loc,y,346,350
ASEL,s,,,92,324,8
NSLA,R
CM,_CONTACT,NODE
TYPE,4
ESLN,S,0
ESURF
ALLSEL
ESEL,ALL
ESEL,S,TYPE,,3
ESEL,A,TYPE,,4
ESEL,R,REAL,,3
/PSYMB,ESYS,1
/PNUM,TYPE,1
/NUM,1
EPLOT
ESEL,ALL
ESEL,S,TYPE,,3
ESEL,A,TYPE,,4
ESEL,R,REAL,,3
CMSEL,A,_NODECM
CMDEL,_NODECM
CMSEL,A,_ELEMCM
CMDEL,_ELEMCM
CMSEL,S,_KPCM
CMDEL,_KPCM
CMSEL,S,_LINECM
CMDEL,_LINECM
CMSEL,S,_AREACM
CMDEL,_AREACM
CMSEL,S,_VOLUCM
CMDEL,_VOLUCM
/GRES,cwz,gsav
CMDEL,_TARGET
CMDEL,_CONTACT
/COM, CONTACT PAIR CREATION - END
CM,_NODECM,NODE
CM,_ELEMCM,ELEM
CM,_KPCM,KP
CM,_LINECM,LINE
CM,_AREACM,AREA
CM,_VOLUCM,VOLU
MP,MU,1,0.1
MAT,1
R,4
REAL,4
ET,5,170
ET,6,174
KEYOPT,6,9,1
KEYOPT,6,10,1
R,4,
RMORE,
RMORE,,0
RMORE,0
ASEL,S,,,6,72,22
CM,_TARGET,AREA
TYPE,5
NSLA,S,1
ESLN,S,0
ESURF
CMSEL,S,_ELEMCM
! Generate the contact surface
NSEL,NONE
csys,13
nsel,s,loc,y,-2,2
nsel,a,loc,y,10,14
nsel,a,loc,y,22,26
nsel,a,loc,y,34,38
nsel,a,loc,y,46,50
nsel,a,loc,y,58,62
nsel,a,loc,y,70,74
nsel,a,loc,y,82,86
nsel,a,loc,y,94,98
ASEL,s,,,95,327,8
NSLA,R
CM,_CONTACT,NODE
TYPE,6
ESLN,S,0
ESURF
ALLSEL
ESEL,ALL
ESEL,S,TYPE,,5
ESEL,A,TYPE,,6
ESEL,R,REAL,,4
/PSYMB,ESYS,1
/PNUM,TYPE,1
/NUM,1
EPLOT
ESEL,ALL
ESEL,S,TYPE,,5
ESEL,A,TYPE,,6
ESEL,R,REAL,,4
CMSEL,A,_NODECM
CMDEL,_NODECM
CMSEL,A,_ELEMCM
CMDEL,_ELEMCM
CMSEL,S,_KPCM
CMDEL,_KPCM
CMSEL,S,_LINECM
CMDEL,_LINECM
CMSEL,S,_AREACM
CMDEL,_AREACM
CMSEL,S,_VOLUCM
CMDEL,_VOLUCM
/GRES,cwz,gsav
CMDEL,_TARGET
CMDEL,_CONTACT
CM,_NODECM,NODE
CM,_ELEMCM,ELEM
CM,_KPCM,KP
CM,_LINECM,LINE
CM,_AREACM,AREA
CM,_VOLUCM,VOLU
MP,MU,1,0.1
MAT,1
R,5
REAL,5
ET,7,170
ET,8,174
KEYOPT,8,9,1
KEYOPT,8,10,1
R,5,
RMORE,
RMORE,,0
RMORE,0
ASEL,S,,,14,58,22
ASEL,a,,,79
CM,_TARGET,AREA
TYPE,7
NSLA,S,1
ESLN,S,0
ESURF
CMSEL,S,_ELEMCM
NSEL,NONE
csys,13
nsel,s,loc,y,-2,2
nsel,a,loc,y,10,14
nsel,a,loc,y,22,26
nsel,a,loc,y,34,38
nsel,a,loc,y,46,50
nsel,a,loc,y,58,62
nsel,a,loc,y,70,74
nsel,a,loc,y,82,86
nsel,a,loc,y,94,98
ASEL,s,,,91,323,8
NSLA,R
CM,_CONTACT,NODE
TYPE,8
ESLN,S,0
ESURF
ALLSEL
ESEL,ALL
ESEL,S,TYPE,,7
ESEL,A,TYPE,,8
ESEL,R,REAL,,5
/PSYMB,ESYS,1
/PNUM,TYPE,1
/NUM,1
EPLOT
ESEL,ALL
ESEL,S,TYPE,,7
ESEL,A,TYPE,,8
ESEL,R,REAL,,5
CMSEL,A,_NODECM
CMDEL,_NODECM
CMSEL,A,_ELEMCM
CMDEL,_ELEMCM
CMSEL,S,_KPCM
CMDEL,_KPCM
CMSEL,S,_LINECM
CMDEL,_LINECM
CMSEL,S,_AREACM
CMDEL,_AREACM
CMSEL,S,_VOLUCM
CMDEL,_VOLUCM
/GRES,cwz,gsav
CMDEL,_TARGET
CMDEL,_CONTACT
CM,_NODECM,NODE
CM,_ELEMCM,ELEM
CM,_KPCM,KP
CM,_LINECM,LINE
CM,_AREACM,AREA
CM,_VOLUCM,VOLU
MP,MU,1,0.1
MAT,1
R,6
REAL,6
ET,9,170
ET,10,174
KEYOPT,10,9,1
KEYOPT,10,10,1
R,6,
RMORE,
RMORE,,0
RMORE,0
ASEL,S,,,20,64,22
ASEL,a,,,84
CM,_TARGET,AREA
TYPE,9
NSLA,S,1
ESLN,S,0
ESURF
CMSEL,S,_ELEMCM
NSEL,NONE
csys,13
nsel,s,loc,y,-2,2
nsel,a,loc,y,10,14
nsel,a,loc,y,22,26
nsel,a,loc,y,34,38
nsel,a,loc,y,46,50
nsel,a,loc,y,58,62
nsel,a,loc,y,70,74
nsel,a,loc,y,82,86
nsel,a,loc,y,94,98
ASEL,S,,,96,328,8
NSLA,R
CM,_CONTACT,NODE
TYPE,10
ESLN,S,0
ESURF
ALLSEL
ESEL,ALL
ESEL,S,TYPE,,9
ESEL,A,TYPE,,10
ESEL,R,REAL,,6
/PSYMB,ESYS,1
/PNUM,TYPE,1
/NUM,1
EPLOT
ESEL,ALL
ESEL,S,TYPE,,9
ESEL,A,TYPE,,10
ESEL,R,REAL,,6
CMSEL,A,_NODECM
CMDEL,_NODECM
CMSEL,A,_ELEMCM
CMDEL,_ELEMCM
CMSEL,S,_KPCM
CMDEL,_KPCM
CMSEL,S,_LINECM
CMDEL,_LINECM
CMSEL,S,_AREACM
CMDEL,_AREACM
CMSEL,S,_VOLUCM
CMDEL,_VOLUCM
/GRES,cwz,gsav
CMDEL,_TARGET
CMDEL,_CONTACT
!挡边
CM,_NODECM,NODE
CM,_ELEMCM,ELEM
CM,_KPCM,KP
CM,_LINECM,LINE
CM,_AREACM,AREA
CM,_VOLUCM,VOLU
MP,MU,1,0.1
MAT,1
R,13
REAL,13
ET,23,170
ET,24,174
KEYOPT,24,9,1
KEYOPT,24,10,1
R,13,
RMORE,
RMORE,,0
RMORE,0
ASEL,S,,,15,59,22
ASEL,a,,,80
CM,_TARGET,AREA
TYPE,23
NSLA,S,1
ESLN,S,0
ESURF
CMSEL,S,_ELEMCM
asel,s,,,89,321,8
CM,_CONTACT,AREA
TYPE,24
NSLA,S,1
ESLN,S,0
ESURF
ALLSEL
ESEL,ALL
ESEL,S,TYPE,,23
ESEL,A,TYPE,,24
ESEL,R,REAL,,13
/PSYMB,ESYS,1
/PNUM,TYPE,1
/NUM,1
EPLOT
ESEL,ALL
ESEL,S,TYPE,,23
ESEL,A,TYPE,,24
ESEL,R,REAL,,13
CMSEL,A,_NODECM
CMDEL,_NODECM
CMSEL,A,_ELEMCM
CMDEL,_ELEMCM
CMSEL,S,_KPCM
CMDEL,_KPCM
CMSEL,S,_LINECM
CMDEL,_LINECM
CMSEL,S,_AREACM
CMDEL,_AREACM
CMSEL,S,_VOLUCM
CMDEL,_VOLUCM
/GRES,cwz,gsav
CMDEL,_TARGET
CMDEL,_CONTACT
CM,_NODECM,NODE
CM,_ELEMCM,ELEM
CM,_KPCM,KP
CM,_LINECM,LINE
CM,_AREACM,AREA
CM,_VOLUCM,VOLU
MP,MU,1,0.1
MAT,1
R,14
REAL,14
ET,25,170
ET,26,174
KEYOPT,26,9,1
KEYOPT,26,10,1
R,14,
RMORE,
RMORE,,0
RMORE,0
ASEL,S,,,85
ASEL,a,,,21,65,22
CM,_TARGET,AREA
TYPE,25
NSLA,S,1
ESLN,S,0
ESURF
CMSEL,S,_ELEMCM
asel,s,,,93,325,8
CM,_CONTACT,AREA
TYPE,26
NSLA,S,1
ESLN,S,0
ESURF
ALLSEL
ESEL,ALL
ESEL,S,TYPE,,25
ESEL,A,TYPE,,26
ESEL,R,REAL,,14
/PSYMB,ESYS,1
/PNUM,TYPE,1
/NUM,1
EPLOT
ESEL,ALL
ESEL,S,TYPE,,25
ESEL,A,TYPE,,26
ESEL,R,REAL,,14
CMSEL,A,_NODECM
CMDEL,_NODECM
CMSEL,A,_ELEMCM
CMDEL,_ELEMCM
CMSEL,S,_KPCM
CMDEL,_KPCM
CMSEL,S,_LINECM
CMDEL,_LINECM
CMSEL,S,_AREACM
CMDEL,_AREACM
CMSEL,S,_VOLUCM
CMDEL,_VOLUCM
/GRES,cwz,gsav
CMDEL,_TARGET
CMDEL,_CONTACT
本人为在校学生,现做毕业设计题是一轧机轴承的热结构耦合分析,给滚动体表面加温度载荷,第一步热分析,我现在做接触的时候遇到困难是1:结点不会找;2:接触对的参数设置不会设,还请斑主以及各位专家指点帮忙修改下,我的邮箱是: tianbo1352@163.com, ,不胜感激
/COM,
/COM, Structural
/COM, Thermal
/filname,CAD-3-0,1
!设置单元和材料属性
/PREP7
ET,1,SOLID70
mp,kxx,1,66.6
!建模
/Prep7
k,26,0,0,0
k,27,270,0,0
!点生成线
l,1,2
l,2,3
l,3,4
l,4,5
l,5,1
l,6,7
l,7,8
l,8,9
l,9,10
l,10,11
l,11,12
l,12,6
l,13,14
l,14,15
l,15,16
l,16,17
l,17,18
l,18,19
l,19,13
!线生成面
al,1,2,3,4,5
!划分单元
/Prep7
!外圈
lsel,s,,,2,3,1
lsel,s,,,5
lsel,s,,,1
lsel,a,,,4
lsel,s,,,10
lsel,a,,,15
lsel,s,,,6
lsel,a,,,8
lsel,s,,,12
lsel,a,,,17
lsel,s,,,11
lsel,a,,,16
lsel,s,,,7
lsel,a,,,19
lsel,s,,,9
lsel,a,,,14
lsel,s,,,8
lsel,a,,,13
!绕26-27转生面体
lsel,s,,,25,29,1
lsel,s,,,63,67,1
lsel,s,,,101,105,1
lsel,s,,,134,138,1
lsel,s,,,134,138,1
lsel,s,,,75,81,1
lsel,s,,,89,95,1
lsel,s,,,113,119,1
lsel,s,,,127,133,1
lsel,s,,,139,152,1
lsel,s,,,37,43,1
lsel,s,,,51,57,1
vsweep,1
vsweep,2
vsweep,3
vsweep,4
vsweep,5
vsweep,6
vsweep,7
vsweep,8
vsweep,9
vsweep,10
vsweep,11
vsweep,12
!定义工作平面
kwplan,1,20,21,11
!旋转工作平面
wprota,,,90
!定义局部坐标系
cswpla,11,1
!在工作面上生成锥体
定义工作平面
kwplan,1,23,24,11
!旋转工作面
wprota,,,90
!定义局部坐标系
cswpla,12,1
!在工作面上生成锥体
!压缩定义的项目编码
numcmp,all
!滚子
lsel,s,,,153,160,1
lsel,a,,,163,170,1
lsel,s,,,161,162,1
lsel,a,,,171,172,1
vsweep,13
vsweep,14
!坐标系
csys,0
k,109,0,0,100
!三个关键点定义局部坐标系的
!激活先前定义的坐标系
csys,13
!滚子
!生成接触对
!滚子与滚道
ALLSEL,ALL
CM,_NODECM,NODE
CM,_ELEMCM,ELEM
CM,_KPCM,KP
CM,_LINECM,LINE
CM,_AREACM,AREA
CM,_VOLUCM,VOLU
!摩擦系数
MP,MU,1,0.1
MAT,1
R,3
REAL,3
ET,3,170
ET,4,174
KEYOPT,4,9,1
KEYOPT,4,10,1
R,3,
RMORE,
RMORE,,0
RMORE,0
!选择面
ASEL,S,,,5,71,22
CM,_TARGET,AREA
TYPE,3
NSLA,S,1
ESLN,S,0
ESURF
CMSEL,S,_ELEMCM
NSEL,NONE
csys,13
nsel,s,loc,y,-2,2
nsel,a,loc,y,10,14
nsel,a,loc,y,22,26
nsel,a,loc,y,34,38
nsel,a,loc,y,46,50
nsel,a,loc,y,58,62
nsel,a,loc,y,70,74
nsel,a,loc,y,82,86
nsel,a,loc,y,94,98
ASEL,s,,,92,324,8
NSLA,R
CM,_CONTACT,NODE
TYPE,4
ESLN,S,0
ESURF
ALLSEL
ESEL,ALL
ESEL,S,TYPE,,3
ESEL,A,TYPE,,4
ESEL,R,REAL,,3
/PSYMB,ESYS,1
/PNUM,TYPE,1
/NUM,1
EPLOT
ESEL,ALL
ESEL,S,TYPE,,3
ESEL,A,TYPE,,4
ESEL,R,REAL,,3
CMSEL,A,_NODECM
CMDEL,_NODECM
CMSEL,A,_ELEMCM
CMDEL,_ELEMCM
CMSEL,S,_KPCM
CMDEL,_KPCM
CMSEL,S,_LINECM
CMDEL,_LINECM
CMSEL,S,_AREACM
CMDEL,_AREACM
CMSEL,S,_VOLUCM
CMDEL,_VOLUCM
/GRES,cwz,gsav
CMDEL,_TARGET
CMDEL,_CONTACT
CM,_NODECM,NODE
CM,_ELEMCM,ELEM
CM,_KPCM,KP
CM,_LINECM,LINE
CM,_AREACM,AREA
CM,_VOLUCM,VOLU
MP,MU,1,0.1
MAT,1
R,4
REAL,4
ET,5,170
ET,6,174
KEYOPT,6,9,1
KEYOPT,6,10,1
R,4,
RMORE,
RMORE,,0
RMORE,0
ASEL,S,,,6,72,22
CM,_TARGET,AREA
TYPE,5
NSLA,S,1
ESLN,S,0
ESURF
CMSEL,S,_ELEMCM
NSEL,NONE
csys,13
nsel,s,loc,y,-2,2
nsel,a,loc,y,10,14
nsel,a,loc,y,22,26
nsel,a,loc,y,34,38
nsel,a,loc,y,46,50
nsel,a,loc,y,58,62
nsel,a,loc,y,70,74
nsel,a,loc,y,82,86
nsel,a,loc,y,94,98
ASEL,s,,,95,327,8
NSLA,R
CM,_CONTACT,NODE
TYPE,6
ESLN,S,0
ESURF
ALLSEL
ESEL,ALL
ESEL,S,TYPE,,5
ESEL,A,TYPE,,6
ESEL,R,REAL,,4
/PSYMB,ESYS,1
/PNUM,TYPE,1
/NUM,1
EPLOT
ESEL,ALL
ESEL,S,TYPE,,5
ESEL,A,TYPE,,6
ESEL,R,REAL,,4
CMSEL,A,_NODECM
CMDEL,_NODECM
CMSEL,A,_ELEMCM
CMDEL,_ELEMCM
CMSEL,S,_KPCM
CMDEL,_KPCM
CMSEL,S,_LINECM
CMDEL,_LINECM
CMSEL,S,_AREACM
CMDEL,_AREACM
CMSEL,S,_VOLUCM
CMDEL,_VOLUCM
/GRES,cwz,gsav
CMDEL,_TARGET
CMDEL,_CONTACT
CM,_NODECM,NODE
CM,_ELEMCM,ELEM
CM,_KPCM,KP
CM,_LINECM,LINE
CM,_AREACM,AREA
CM,_VOLUCM,VOLU
MP,MU,1,0.1
MAT,1
R,5
REAL,5
ET,7,170
ET,8,174
KEYOPT,8,9,1
KEYOPT,8,10,1
R,5,
RMORE,
RMORE,,0
RMORE,0
ASEL,S,,,14,58,22
ASEL,a,,,79
CM,_TARGET,AREA
TYPE,7
NSLA,S,1
ESLN,S,0
ESURF
CMSEL,S,_ELEMCM
NSEL,NONE
csys,13
nsel,s,loc,y,-2,2
nsel,a,loc,y,10,14
nsel,a,loc,y,22,26
nsel,a,loc,y,34,38
nsel,a,loc,y,46,50
nsel,a,loc,y,58,62
nsel,a,loc,y,70,74
nsel,a,loc,y,82,86
nsel,a,loc,y,94,98
ASEL,s,,,91,323,8
NSLA,R
CM,_CONTACT,NODE
TYPE,8
ESLN,S,0
ESURF
ALLSEL
ESEL,ALL
ESEL,S,TYPE,,7
ESEL,A,TYPE,,8
ESEL,R,REAL,,5
/PSYMB,ESYS,1
/PNUM,TYPE,1
/NUM,1
EPLOT
ESEL,ALL
ESEL,S,TYPE,,7
ESEL,A,TYPE,,8
ESEL,R,REAL,,5
CMSEL,A,_NODECM
CMDEL,_NODECM
CMSEL,A,_ELEMCM
CMDEL,_ELEMCM
CMSEL,S,_KPCM
CMDEL,_KPCM
CMSEL,S,_LINECM
CMDEL,_LINECM
CMSEL,S,_AREACM
CMDEL,_AREACM
CMSEL,S,_VOLUCM
CMDEL,_VOLUCM
/GRES,cwz,gsav
CMDEL,_TARGET
CMDEL,_CONTACT
CM,_NODECM,NODE
CM,_ELEMCM,ELEM
CM,_KPCM,KP
CM,_LINECM,LINE
CM,_AREACM,AREA
CM,_VOLUCM,VOLU
MP,MU,1,0.1
MAT,1
R,6
REAL,6
ET,9,170
ET,10,174
KEYOPT,10,9,1
KEYOPT,10,10,1
R,6,
RMORE,
RMORE,,0
RMORE,0
ASEL,S,,,20,64,22
ASEL,a,,,84
CM,_TARGET,AREA
TYPE,9
NSLA,S,1
ESLN,S,0
ESURF
CMSEL,S,_ELEMCM
NSEL,NONE
csys,13
nsel,s,loc,y,-2,2
nsel,a,loc,y,10,14
nsel,a,loc,y,22,26
nsel,a,loc,y,34,38
nsel,a,loc,y,46,50
nsel,a,loc,y,58,62
nsel,a,loc,y,70,74
nsel,a,loc,y,82,86
nsel,a,loc,y,94,98
ASEL,S,,,96,328,8
NSLA,R
CM,_CONTACT,NODE
TYPE,10
ESLN,S,0
ESURF
ALLSEL
ESEL,ALL
ESEL,S,TYPE,,9
ESEL,A,TYPE,,10
ESEL,R,REAL,,6
/PSYMB,ESYS,1
/PNUM,TYPE,1
/NUM,1
EPLOT
ESEL,ALL
ESEL,S,TYPE,,9
ESEL,A,TYPE,,10
ESEL,R,REAL,,6
CMSEL,A,_NODECM
CMDEL,_NODECM
CMSEL,A,_ELEMCM
CMDEL,_ELEMCM
CMSEL,S,_KPCM
CMDEL,_KPCM
CMSEL,S,_LINECM
CMDEL,_LINECM
CMSEL,S,_AREACM
CMDEL,_AREACM
CMSEL,S,_VOLUCM
CMDEL,_VOLUCM
/GRES,cwz,gsav
CMDEL,_TARGET
CMDEL,_CONTACT
!挡边
CM,_NODECM,NODE
CM,_ELEMCM,ELEM
CM,_KPCM,KP
CM,_LINECM,LINE
CM,_AREACM,AREA
CM,_VOLUCM,VOLU
MP,MU,1,0.1
MAT,1
R,13
REAL,13
ET,23,170
ET,24,174
KEYOPT,24,9,1
KEYOPT,24,10,1
R,13,
RMORE,
RMORE,,0
RMORE,0
ASEL,S,,,15,59,22
ASEL,a,,,80
CM,_TARGET,AREA
TYPE,23
NSLA,S,1
ESLN,S,0
ESURF
CMSEL,S,_ELEMCM
asel,s,,,89,321,8
CM,_CONTACT,AREA
TYPE,24
NSLA,S,1
ESLN,S,0
ESURF
ALLSEL
ESEL,ALL
ESEL,S,TYPE,,23
ESEL,A,TYPE,,24
ESEL,R,REAL,,13
/PSYMB,ESYS,1
/PNUM,TYPE,1
/NUM,1
EPLOT
ESEL,ALL
ESEL,S,TYPE,,23
ESEL,A,TYPE,,24
ESEL,R,REAL,,13
CMSEL,A,_NODECM
CMDEL,_NODECM
CMSEL,A,_ELEMCM
CMDEL,_ELEMCM
CMSEL,S,_KPCM
CMDEL,_KPCM
CMSEL,S,_LINECM
CMDEL,_LINECM
CMSEL,S,_AREACM
CMDEL,_AREACM
CMSEL,S,_VOLUCM
CMDEL,_VOLUCM
/GRES,cwz,gsav
CMDEL,_TARGET
CMDEL,_CONTACT
CM,_NODECM,NODE
CM,_ELEMCM,ELEM
CM,_KPCM,KP
CM,_LINECM,LINE
CM,_AREACM,AREA
CM,_VOLUCM,VOLU
MP,MU,1,0.1
MAT,1
R,14
REAL,14
ET,25,170
ET,26,174
KEYOPT,26,9,1
KEYOPT,26,10,1
R,14,
RMORE,
RMORE,,0
RMORE,0
ASEL,S,,,85
ASEL,a,,,21,65,22
CM,_TARGET,AREA
TYPE,25
NSLA,S,1
ESLN,S,0
ESURF
CMSEL,S,_ELEMCM
asel,s,,,93,325,8
CM,_CONTACT,AREA
TYPE,26
NSLA,S,1
ESLN,S,0
ESURF
ALLSEL
ESEL,ALL
ESEL,S,TYPE,,25
ESEL,A,TYPE,,26
ESEL,R,REAL,,14
/PSYMB,ESYS,1
/PNUM,TYPE,1
/NUM,1
EPLOT
ESEL,ALL
ESEL,S,TYPE,,25
ESEL,A,TYPE,,26
ESEL,R,REAL,,14
CMSEL,A,_NODECM
CMDEL,_NODECM
CMSEL,A,_ELEMCM
CMDEL,_ELEMCM
CMSEL,S,_KPCM
CMDEL,_KPCM
CMSEL,S,_LINECM
CMDEL,_LINECM
CMSEL,S,_AREACM
CMDEL,_AREACM
CMSEL,S,_VOLUCM
CMDEL,_VOLUCM
/GRES,cwz,gsav
CMDEL,_TARGET
CMDEL,_CONTACT
