有人做过三维谐波磁场分析吗?或者用solid97单元模拟载压线圈??急急急!!!
浏览:152357
用solid97单元模拟载压线圈时,“DIRX, DIRY, DIRZ x, y, and z components of a unit vector (in the element coordinate system) representing the direction of current. Required for a stranded coil only.”
“ stranded coil”是什么意思啊?
应该怎么设呢?
