一个固定副的错误
浏览:104630
JOINT_25 是固定副,只需选2个body和1个location,哪里来的I marker,J marker
ERROR: JOINT lizi.JOINT_25 is not specified correctly.
The x-axis of the I marker and the x-axis of the J marker have
a relative angle of 85.702 degrees. The angle between the axes
should be 0 degrees.
