dynaform中的messaner文件?
浏览:135507 回答:16
请问群中各位高手,DF中的messaner如何查看啊??
(16)
njfcn973
还有,如果网格划到时,把时间步调小到-1.2e-007,又会出现warning slave nodes may cross the surface 的警告
Date: 11/20/2009 Time: 15:56:27
___________________________________________________
| Livermore Software Technology Corporation |
| 7374 Las Positas Road |
| Livermore, CA 94551 |
| Tel: (925) 449-2500 Fax: (925) 449-2507 |
| www.lstc.com |
|_________________________________________________|
| LS-DYNA, A Program for Nonlinear Dynamic |
| Analysis of Structures in Three Dimensions |
| Version: 970 Date: 01/10/2005 |
| Revision: 5434a Time: 18:01:01 |
| Licensed to: |
| Platform : PC WIN32(PCWIN) |
| OS Level : WINDOWS XP |
| Hostname : 97805265f60a4b0 |
| Precision : Single precision (I4R4) |
| Unauthorized use infringes LSTC copyrights |
Input file: e:/dy/gaihou~1/shiyan.dyn
The native file format : 32-bit small endian
Memory size from command line: 52428800
Memory option : AUTO selected
expanding memory to 52428800
******** notice ******** notice ******** notice ********
* This is the LS-DYNA Explicit Finite Element code. *
* Neither LSTC nor the authors assume any responsibility for *
* the validity, accuracy, or applicability of any results *
* obtained from this system. The user must verify his own *
* results. *
* LSTC endeavors to make the LS-DYNA code as complete, *
* accurate and easy to use as possible. *
* Suggestions and comments are welcomed. Please report any *
* errors encountered in either the documentation or results *
* immediately to LSTC through your site focus. *
* Copyright (C) 1990-2005 *
* by Livermore Software Technology Corp. (LSTC) *
* All rights reserved *
contracting memory to 162592
expanding memory to 305184
expanding memory to 509670
expanding memory to 554670
expanding memory to 584670
expanding memory to 1060446
expanding memory to 1122745
expanding memory to 1147251
expanding memory to 1167537
Open include file: shiyan.mod
expanding memory to 1533002
expanding memory to 1567650
expanding memory to 1602298
expanding memory to 1635379
expanding memory to 1668460
expanding memory to 1701541
expanding memory to 1805485
expanding memory to 1838566
expanding memory to 1873214
expanding memory to 3120550
expanding memory to 3728545
expanding memory to 3763193
expanding memory to 3796274
expanding memory to 3829355
contracting memory to 2
LS-DYNA will perform a structural only analysis
UNTITLED
ls-dyna (version 970 ) date 01/10/2005
*** Warning reset D3PLOT ouput interval from 0. to 4.1300E-03
expanding memory to 2773
expanding memory to 17898
expanding memory to 245729
expanding memory to 2490232
expanding memory to 2524860
expanding memory to 3505026
expanding memory to 3507067
expanding memory to 3508836
expanding memory to 3541715
expanding memory to 3541833
expanding memory to 3544834
expanding memory to 3642968
expanding memory to 3642970
expanding memory to 3974577
expanding memory to 4010996
expanding memory to 4260472
expanding memory to 5218233
expanding memory to 5317835
expanding memory to 6202974
expanding memory to 6302217
expanding memory to 6718824
contracting memory to 6718824
expanding memory to 6718904
expanding memory to 6718914
contracting memory to 6718914
expanding memory to 6718918
contracting memory to 6718918
expanding memory to 6857510
master surface has 14138 segments, 0 renumbered
slave surface has 6408 segments, 0 renumbered
master surface has 8905 segments, 0 renumbered
master surface has 5197 segments, 0 renumbered
The LS-DYNA time step size should not exceed 0.276E-06
to avoid contact instabilities. If the step size is
bigger then scale the penalty of the offending surface.
Slave side interface # 2
# nodes on + segment side = 451 max dist = 2.60964E+01 min dist = 6.02693E-01
# nodes on - segment side = 482 max dist = 2.63431E+01 min dist = 6.80952E-01
*** Warning slave nodes may cross the surface
please check your model, job continues
Master side interface # 2
# nodes on + segment side = 500 max dist = 1.09449E+01 min dist = 6.23693E-01
# nodes on - segment side = 483 max dist = 1.11079E+01 min dist = 6.19686E-01
Slave side interface # 3
# nodes on + segment side = 0 max dist =-1.00000E+10 min dist = 1.00000E+10
# nodes on - segment side = 342 max dist = 2.56881E+01 min dist = 7.25722E+00
Master side interface # 3
# nodes on - segment side = 27 max dist = 1.10572E+01 min dist = 7.76325E+00
calculation with mass scaling for minimum dt
added mass = 4.5039E-07
physical mass= 3.0417E-02
ratio = 1.4807E-05
1 t 0.0000E+00 dt 1.08E-07 flush i/o buffers
1 t 0.0000E+00 dt 1.08E-07 write d3plot file
Slave side interface # 1
# nodes on + segment side = 1 max dist = 6.80323E+00 min dist = 6.80323E+00
# nodes on - segment side = 0 max dist =-1.00000E+10 min dist = 1.00000E+10
Master side interface # 1
# nodes on + segment side = 7737 max dist = 2.15438E+02 min dist = 9.67714E-03
# nodes on - segment side = 5371 max dist = 7.53516E+02 min dist = 2.22206E-03
3830 t 2.0651E-03 dt 5.35E-07 write adaptivity stress file
expanding memory to 162592
expanding memory to 1082648
expanding memory to 1449913
expanding memory to 1484561
expanding memory to 1519209
expanding memory to 1552290
expanding memory to 1585371
expanding memory to 1618452
expanding memory to 1722396
expanding memory to 1755477
expanding memory to 1790125
expanding memory to 3037461
expanding memory to 3645456
expanding memory to 3680104
expanding memory to 3713185
expanding memory to 3746266
expanding memory to 3812428
expanding memory to 3847509
expanding memory to 4027509
expanding memory to 4048109
expanding memory to 4082109
expanding memory to 4168509
expanding memory to 4190109
expanding memory to 4211009
expanding memory to 4242409
expanding memory to 4328809
expanding memory to 4350409
expanding memory to 4371309
expanding memory to 4402709
expanding memory to 4489109
expanding memory to 4510709
3830 t 2.0651E-03 dt 5.35E-07 increase shells from 34648 to 43018
expanding memory to 4555231
expanding memory to 4597053
expanding memory to 6857520
expanding memory to 304690
expanding memory to 3111630
expanding memory to 3154628
expanding memory to 4848941
expanding memory to 4850982
expanding memory to 4852751
expanding memory to 4894371
expanding memory to 4894489
expanding memory to 4897490
expanding memory to 5021847
expanding memory to 5021849
expanding memory to 5551010
expanding memory to 5603948
expanding memory to 5930980
expanding memory to 7322024
expanding memory to 7447849
expanding memory to 8739201
expanding memory to 8864667
expanding memory to 9517281
contracting memory to 9517281
expanding memory to 9517361
expanding memory to 9517371
contracting memory to 9517371
expanding memory to 9521907
expanding memory to 9521911
contracting memory to 9521911
expanding memory to 9705143
expanding memory to 9877215
3830 t 2.0651E-03 dt 5.35E-07 flush i/o buffers
2009年11月20日
njfcn973
请问版主说的问题是板料网格边线和白线没有重合吗?在那个模拟中我已经把板料网格划到5了,刚才又试了下6/7/8/9,可依然存在那个问题,划到10就可以了,但前几天我就是划到10计算的,结果会出现# node * has out-of-range velocities 的错误。这可该怎么改啊?
2009年11月20日
芜湖小铁匠
你的板料网格有问题,你check下
2009年11月20日
njfcn973
DYN在这里,刚传错了
2009年11月19日
njfcn973
不好意思啊,没有找到你说的BLK文件
2009年11月19日
njfcn973
2009年11月19日
njfcn973
文件在这里
2009年11月19日
芜湖小铁匠
恩,有的节点飞掉了
你把DYN MOD BLK文件传上来,我帮你看看
2009年11月19日
njfcn973
红/蓝色是模具,棕/粉色是坯料和压料圈。第四步时坯料纵向的中间部才刚刚变形变形,边缘不可能是那样啊
2009年11月18日
njfcn973
谢谢版主。我把坯料网格划细了些,能计算了,可算到第四步坯料边缘破裂,算到第五步就完了,实际不该是这样啊。为了说清楚,把图附上
2009年11月18日
