问题
浏览:95591 回答:1
*** Warning reset D3PLOT output interval from 0. to 5.5000E-04
expanding memory to 3021 material, node and element data
expanding memory to 21907 material properties
expanding memory to 138284 element data
expanding memory to 1282079 user control for contact interfaces
这是什么意思呢?
下面的警告又是什么意思呢?
*** Warning slave nodes may cross the surface
please check your model, job continues
Master side interface # 3
# nodes on + segment side = 71 max dist = 5.03917E-01 min dist =-4.99500E-01
# nodes on - segment side = 120 max dist = 8.58346E-01 min dist =-4.52839E-01
请高手指点下
这是什么意思呢?
下面的警告又是什么意思呢?
请高手指点下
