新手模态分析时错误 请求高手指点 不胜感激
浏览:127136 回答:1
*** OptiStruct defaults set from:
install config file: C:\Altair\hw10.0/hwsolvers/hwsolver.cfg
*** ERROR # 173 ***
A dependent d.o.f. defined more than once in rigid element entry.
grid id = 1307
component = 1
*** ERROR # 173 ***
grid id = 1307
component = 2
*** ERROR # 173 ***
grid id = 1307
component = 3
*** ERROR # 173 ***
grid id = 1307
component = 4
*** ERROR # 173 ***
grid id = 1307
component = 5
*** ERROR # 173 ***
grid id = 1307
component = 6
*** ERROR # 173 ***
grid id = 3917
component = 1
*** ERROR # 173 ***
grid id = 3917
component = 2
*** ERROR # 173 ***
grid id = 3917
component = 3
*** ERROR # 173 ***
grid id = 3917
component = 4
yxg**in_HfHL
好象是刚性单元3917和1307有多余约束自由度 你查下这两个单元的位置,减少约束试下
2010年1月26日
