请教ABAQUS分析裂纹扩展inp文件的相关问题
浏览:80254 回答:2
我在txt文件里编辑了有关紧凑拉伸试样(CT试样)在拉应力作用下的裂纹扩展的inp文件(见附件ct3),然后在abaqus中运行后,结果提示有错误(具体见附件ct3_result),由于我知识浅薄尚不知该怎样修改,请高手赐教,不胜感激!
***ERROR: The area of 408 elements is zero, small, or negative. Check
coordinates or node numbering, or modify the mesh seed. The elements
have been identified in element set ErrElemAreaSmallNegZero.
***NOTE: DUE TO AN INPUT ERROR THE ANALYSIS PRE-PROCESSOR HAS BEEN UNABLE TO
INTERPRET SOME DATA. SUBSEQUENT ERRORS MAY BE CAUSED BY THIS OMISSION
请问您会输出裂纹扩展寿命吗?
