结构、流体、热的三场耦合
浏览:92453 回答:3
我做的是15万立方米的储罐,罐外温度是零下20度,油温度是50度,这是结构、流体、热的三场耦合问题,我在ADINA Structure中建的是罐的模型,在ADINA CFD中建的是流体的模型。可是,在Solution---Run ADINA-FSI求解时弹出对话框,后缀是.out的文件内容为: ****************************************************************************************************************
* * A FINITE ELEMENT PROGRAM FOR * *
* * AUTOMATIC DYNAMIC INCREMENTAL NONLINEAR ANALYSIS * *
* * -- F S I -- * *
* * AAAAAA DDDDDDDDDD IIIIIIIIIIIIIII NNN NNN AAAAAA * *
* * AAAAAAAAAA DDDDDDDDDDDD IIIIIIIIIIIIIII NNNN NNN AAAAAAAAAA * *
* * AAA AAA DDD DDDD IIII NNNNN NNN AAA AAA * *
* * AAA AAA DDD DDD IIII NNNNNN NNN AAA AAA * *
* * AAA AAA DDD DDD IIII NNNNNNN NNN AAA AAA * *
* * AAA AAA DDD DDD IIII NNN NNNN NNN AAA AAA * *
* * AAAAAAAAAAAAAAAA DDD DDD IIII NNN NNNN NNN AAAAAAAAAAAAAAAA * *
* * AAAAAAAAAAAAAAAA DDD DDD IIII NNN NNNNNNN AAAAAAAAAAAAAAAA * *
* * AAA AAA DDD DDD IIII NNN NNNNNN AAA AAA * *
* * AAA AAA DDD DDDD IIII NNN NNNNN AAA AAA * *
* * AAA AAA DDDDDDDDDDDD IIIIIIIIIIIIIII NNN NNNN AAA AAA * *
* * AAA AAA DDDDDDDDDD IIIIIIIIIIIIIII NNN NNN AAA AAA * *
* * VERSION 8.5.0 (BUILT ON 03-25-2008) * *
THIS PROGRAM IS IN ITS ENTIRETY PROPRIETAARY TO AND IS SUPPORTED AND MAINTAINED BY
ADINA R & D, INC.
71 ELTON AVENUE TEL (617) 926-5199
WATERTOWN, MA 02472, USA TELEFAX (617) 926-0238
email: support@adina.com
ADINA R & D, INC.
MAKES NO WARRANTY THAT THE PROGRAM AND ITS DOCUMENTATION INCLUDING
ANY MODIFICATIONS AND UPDATES A RE FREE FROM ERRORS AND DEFECTS
COPYRIGHT ADINA R&D,INC., 1987,1990,1992,1994,1999-2008
RESTRICTED RIGHTS LEGEND
USE, DUPLICATION, OR DISCLOSURE OF THE ADINA SYSTEM BY THE U.S. GOVERNMENT
IS SUBJECT TO RESTRICTIONS AS SET FORTH IN SUBPARAGRAPH (C)(1)(II) OF THE
RIGHTS IN TECHNICAL DATA AND COMPUTER SOFTWARE CLAUSE AT DFARS 252.227-7013.
ADFSI 8.5.0 (BUILT ON 03-25-2008)
FOR PROBLEM: *** NO HEADING DEFINED ***
LICENSED FROM A D I N A R & D INC.
BC order for moving mesh
2 1 3 4 5 6 7 8 9 10
11 12 13 14 15 16 17 18 19 20
21 22
*** ERROR *** CODE ADF0045:
This is an internal error message.
Unidentified message:Warning(TP_TPINIX): NO solid & porous EGRs in ADINA-F(2100
Please contact ADINA R&D, Inc.
Telephone (617)-926-5199
Telefax (617)-926-0238
Email support@adina.com
* S O L U T I O N T I M E L O G (IN SECONDS) *
CPU IN PROGRAM CONTROL.......................................................... 0.44
CPU IN SOLID MODEL.............................................................. 1.17
CPU IN FLUID MODEL.............................................................. 13.91
CPU IN INPUT PHASE........................................................... 3.25
CPU IN SOLVER................................................................ 1.02
IN GENERATION OF IRA...................................................... 1.02
IN OTHER COMPUTATION IN SOLVER............................................ 0.00
CPU IN MOVING-MESH COMPUTATION............................................... 0.12
IN BOUNDARY ALE........................................................... 0.12
CPU IN OUTPUT................................................................ 9.52
T O T A L S O L U T I O N T I M E............................................. 15.52
1 110 0
后缀为A.log的文件:
** A FINITE ELEMENT PROGRAM FOR **
** AUTOMATIC DYNAMIC INCREMENTAL NONLINEAR ANALYSIS **
** -- S T R U C T U R E S -- **
** AAAAAAAAAA DDDDDDDDD IIIIIIIIIIII NN NN AAAAAAAAAA **
** AAAAAAAAAAAA DDDDDDDDDD IIIIIIIIIIII NNN NN AAAAAAAAAAAA **
** AA AA DD DD II NNNN NN AA AA **
** AA AA DD DD II NN NN NN AA AA **
** AAAAAAAAAAAA DD DD II NN NN NN AAAAAAAAAAAA **
** AA AA DD DD II NN NNNN AA AA **
** AA AA DD DD II NN NNN AA AA **
** AA AA DDDDDDDDDD IIIIIIIIIIII NN NN AA AA **
** AA AA DDDDDDDDD IIIIIIIIIIII NN N AA AA **
** VERSION - 8.5.0 (build 03.25.2008) **
THIS PROGRAM IS IN ITS ENTIRETY PROPRIETARY TO, AND IS SUPPORTED AND MAINTAINED BY
ADINA R&D, Inc.
71 Elton Avenue Tel (617) 926-5199
Watertown, MA 02472, U.S.A. Fax (617) 926-0238
email...: support@adina.com
web site: www.adina.com
USAGE OF THIS PROGRAM AND THE PROGRAM DOCUMENTATION IS
SUBJECT TO THE CONDITIONS IN THE ADINA LICENSE AGREEMENT
COPYRIGHT ADINA R&D,INC., 1987,1990,1992,1994,1999,2000
2001,2002,2003,2004,2005,2006,2007,2008
ADINA IS A REGISTERED TRADEMARK OF K.J. BATHE.
*** ADINA R&D INC. ***
MAKES NO WARRANTY WHATSOEVER, EXPRESSED OR IMPLIED THAT
THE PROGRAM AND ITS DOCUMENTATION ARE FREE FROM ERRORS
AND DEFECTS. IN NO EVENT SHALL ADINA R&D BECOME LIABLE
TO THE USER OR ANY PARTY FOR ANY LOSS, INCLUDING BUT NOT
LIMITED TO, LOSS OF TIME, MONEY OR GOODWILL, WHICH MAY
ARISE FROM THE USE OF THE PROGRAM AND ITS DOCUMENTATION.
COMPUTER VERSION: WINDOWS 98/ME/NT/2000/XP
U.S. GOVERNMENT IS SUBJECT TO RESTRICTIONS AS SET FORTH IN
SUBPARAGRAPH (C)(1)(II) OF THE RIGHTS IN TECHNICAL DATA
Initial ADINA memory allocation - 1600.9 mb (or 400.2 mw)
* THIS IS A NONLINEAR STATIC ANALYSIS *
1PROGRAM ADINA - VERSION 8.5.0 (build 03.25.2008) *** NO HEADING DEFINED ***
S O L U T I O N B Y S P A R S E S O L V E R
TOTAL SYSTEM DATA
NUMBER OF EQUATIONS . . . . . . . . . . . . .(NEQ) = 10000
NUMBER OF NON-ZERO MATRIX TERMS. . . . . . . (NZC) = 224000
MEMORY AVAILABLE FOR STORAGE (in words). .(MSTORE) = 266342516
NUMBER OF PROCESSORS USED. . . . . . . . . (NPROC) = 1
M E M O R Y R E Q U I R E M E N T (in words)
ALLOCATED MEMORY BY THE PROGRAM (MSTORE) = 266342516
ESTIMATED MEMORY FOR IN-CORE STORAGE .......(IOPTIM=3)= 2375073
ESTIMATED MEMORY FOR K-MATRIX IN-CORE ONLY..(IOPTIM=2)= 2087066
NOTE: WHEN SPARSE SOLVER IS USED - ADDITIONAL MEMORY
IS REQUIRED - PLEASE SEE BELOW INFORMATION
RELATED TO SPARSE SOLVERS.
MAXIMUM REQUESTED (TEMPORARY) MEMORY (in words)...... = 2375073
IN-CORE STORAGE FLAG . . . . . . . . . . . (IOPTIM) = 3
Available total memory . . . . . . . . . . . . . 1065.4 mb
Memory used for storage of model data. . . . . . 11.1 mb
后缀为F.log的文件:
* * -- F S I -- * *
ADINA R & D, INC.
ADINA R & D, INC.
* * -- F S I -- * *
ADINA R & D, INC.
ADINA R & D, INC.
21 22
1 110 0
后缀为A.log的文件:
ADINA R&D, Inc.
TOTAL SYSTEM DATA
后缀为F.log的文件:
* * -- F S I -- * *
ADINA R & D, INC.
ADINA R & D, INC.
图片和命令流见下附件:
