fluent 并行计算错误,应该怎么改?
浏览:83574
12.1的ansys 不一段时间就出错,出错代码是MPI Application rank 1 exited before MPI_Finalize() with status -1073740777
999999 (..\src\mpsystem.c@1149): mpt_read: failed: errno = 10054
999999: mpt_read: error: read failed trying to read 4 bytes: Invalid argument
The Parallel FLUENT process could not be started.
