子弹侵彻钢板问题
浏览:178879 回答:3
为什么我的子弹侵彻钢板例子中,子弹不动啊,已经施加了速度了,而且照着万水那本参考书做的,然后我把这个k文件用ls-prepost软件进行格式转换为v970,再求解器求解为什么子弹不动啊?
*KEYWORD
*TITLE
*DATABASE_FORMAT
0
$ NODE DEFINITIONS $
*NODE
1-8.682408883E-01 4.924038765E+00 0.000000000E+00 0 0
2-8.682408883E-01 4.924038765E+00-7.500000000E-01 0 0
3-8.682408883E-01 4.924038765E+00-1.250000000E-01 0 0
35654 2.550000000E+00-1.350000000E+00-1.333333333E-01 0 0
35655 2.700000000E+00-1.350000000E+00-1.333333333E-01 0 0
35656 2.850000000E+00-1.350000000E+00-1.333333333E-01 0 0
$ SECTION DEFINITIONS $
*SECTION_SOLID
1 1
$ MATERIAL DEFINITIONS $
*MAT_ JOHNSON_COOK
1,7.80,0.77
7.9E-3,5.1E-3,0.27,0.015,1.05,1.8E+3,293,1.1E-6
0.47E-5,-9.0,3.0,0.00,0.78,
0.00
*EOS_GRUNEISEN
1,0.47,1.49,0.00,0.00,2.15,0.455,0.00
1.00
*MAT_JOHNSON_COOK
2,7.80,0.77
0.00
*EOS_GRUNEISEN
2,0.47,1.49,0.00,0.00,2.15,0.455,0.00
1.00
$ 9ARTS DEFINITIONS $
*PART
Part 1 for Mat 1 and Elem Type 1
1 1 1 1 0 0 0
*PART
Part 2 for Mat 2 and Elem Type 1
2 1 2 2 0 0 0
$ ELEMENT DEFINITIONS $
*ELEMENT_SOLID
1 1 5 20 26 4 594 626 800 593
2 1 20 21 28 26 626 655 858 800
30418 2 34564 35110 31017 31018 8203 8204 8197 8196
30419 2 35110 35656 31016 31017 8204 8205 8198 8197
30420 2 35656 31302 31015 31016 8205 8191 8177 8198
$ COORDINATE SYSTEMS $
$ LOAD DEFINITIONS $
$ RIGID BOUNDRIES $
$ BOUNDARY DEFINITIONS $
*SET_NODE_LIST
1 0.000 0.000 0.000 0.000
1 8 14 15 16 17 18 68
74 75 76 77 78 79 80 81
22893 22894 22895 22896 22897 22898 22899 22900
22901 22902 22903
*BOUNDARY_SPC_SET
2 0 1 1 1 0 0 0
$ CONTACT DEFINITIONS $
*CONTACT_ERODING_SURFACE_TO_SURFACE
1 2 3 3 0 0 0 0
0.1500 0.1000 0.000 0.000 0.000 0 0.000 0.1000E+08
1.000 1.000 0.000 0.000 1.000 1.000 1.000 1.000
0 1 0
*CONTROL_CONTACT
10.0
$ CONTROL OPTIONS $
*CONTROL_ENERGY
2 2 2 2
*CONTROL_SHELL
20.0 1 -1 1 2 2 1
*CONTROL_BULK_VISCOSITY
1.00 0.600E-01
*CONTROL_TIMESTEP
0.0000 0.6000 0 0.00 0.00
*CONTROL_TERMINATION
100. 0 0.00000 0.00000 0.00000
*DATABASE_HISTORY_NODE
$ TIME HISTORY $
*DATABASE_GLSTAT
0.5000
*DATABASE_MATSUM
0.5000
*DATABASE_RCFORC
0.5000
*DATABASE_BINARY_D3PLOT
0.5000
*DATABASE_BINARY_D3THDT
0.5000
$ DATABASE OPTIONS $
*DATABASE_EXTENT_BINARY
0 0 3 1 0 0 0 0
0 0 4 0 0 0
$ INITIAL VELOCITY DEFINITIONS $
*SET_NODE_LIST
3 0.000 0.000 0.000 0.000
1 2 3 4 5 6 7 8
9 10 11 12 13 14 15 16
2065 2066 2067 2068 2069 2070 2071 2072
2073 2074 2075 2076 2077
*INITIAL_VELOCITY_GENERATION
3 3 0.00 0.174E-01-0.985E-01 0.00
0.00 0.00 0.00 1.00 1.00 1.00 0
*END
happy44fan
问题解决了吗?我也学习这个 ,我给你看看。
2014年4月29日
xiaoliuyunxiao
可以直接用dyna求解器运行k文件啊,还转换干嘛
2014年4月2日
xiaozheyouyou
我是初学者,请教各位高手,帮帮忙,给看看,感激不尽!!
2012年9月20日
