一个设置问题
浏览:49818 回答:1
Error 70021 (OTH+21) (processor # 0)
Memory is set 10995724 words short
memory size 20000000
Increase the memory size by one of the following
where #### is the number of words requested:
1) On the command line set - memory=####
2) In the input file define memory with *KEYWORD
i.e., *KEYWORD #### or *KEYWORD memory=####
请问下大家这个问题具体怎么解决,谢了。
newsgae
co-ask
Is that means the physical memory of the computer should be increased?
Or there is a way to reallocate the memory usage in the keyword file?
2014年1月8日
