ansys 问题
浏览:54174 回答:3
Open of file shitanxi001.PCS for append failed.
这个错误怎么解决
ANSYSUser1999
把控制/打开"shitanxi001.PCS" 文件的命令改一下, 让它可以append (追加/添加), 不要lock
2012年10月23日
hjhlfz
(C) Copyright 1992-2004
Computational Applications and System Integration Inc.
All rights Reserved.
Job:shitanxi001 at:Wed Oct 17 07:52:27 2012
Number of Processors: 1
Degrees of Freedom: 283498
DOF Constraints: 4461
Elements: 87263
Assembled: 87263
Implicit: 0
Nodes: 88897
Number of Load Cases: 1
Nonzeros in Upper Triangular part of
Global Stiffness Matrix : 9628969
Nonzeros in Preconditioner: 4604467
*** Precond Reorder: MLD ***
Nonzeros in V: 1700127
Nonzeros in factor: 2286843
*** Primal Preconditioner Activated ***
*** Level of Difficulty: 0 ***
Total Operation Count: 8.09684e+013
Total Iterations In PCG: 1333456
Average Iterations Per Load Case: 1333456.0
Input PCG Error Tolerance: 1e-008
Achieved PCG Error Tolerance: 0
DETAILS OF PCG SOLVER SETUP TIME(secs) Cpu Wall
Gather Finite Element Data 0.25 0.31
Element Matrix Assembly 4.13 6.24
DETAILS OF PCG SOLVER SOLUTION TIME(secs) Cpu Wall
Preconditioner Construction 0.30 1.96
Preconditioner Factoring 0.55 3.47
Apply Boundary Conditions 0.50 1.65
Preconditioned CG Iterations 2266.48 2456.68
Multiply With A 1395.87 1486.49
Multiply With A22 1332.25 1416.92
Solve With Precond 693.78 739.82
Solve With Bd 113.01 118.68
Multiply With V 328.13 347.01
Direct Solve 224.74 242.39
TOTAL PCG SOLVER SOLUTION CP TIME = 0.00 secs
TOTAL PCG SOLVER SOLUTION ELAPSED TIME = 0.00 secs
Estimate of Memory Usage In CG : 133.12 MB
Estimate of Disk Usage In CG : 135.41 MB
Memory Usage for Matrix : 94.04 MB
Multiply with A MFLOP Rate : 34042.08 MFlops
Solve With Precond MFLOP Rate : 34684.55 MFlops
Precond Factoring MFLOP Rate : 196.24 MFlops
Job:shitanxi001 at:Wed Oct 17 08:06:00 2012
Elements: 87263
Assembled: 87263
Implicit: 0
Nodes: 88897
Total Operation Count: 8.09685e+013
Total Iterations In PCG: 1333457
Average Iterations Per Load Case: 1333457.0
Achieved PCG Error Tolerance: 2200.29
Gather Finite Element Data 0.20 0.22
Element Matrix Assembly 3.99 5.22
Preconditioner Construction 0.25 0.49
Preconditioner Factoring 0.47 0.65
Apply Boundary Conditions 0.50 2.00
Preconditioned CG Iterations 577.13 669.56
Multiply With A 359.41 387.02
Multiply With A22 342.50 368.98
Solve With Precond 178.18 194.07
Solve With Bd 27.60 30.67
Multiply With V 83.79 91.68
Direct Solve 59.81 63.46
Multiply with A MFLOP Rate : 130752.49 MFlops
Solve With Precond MFLOP Rate : 132173.77 MFlops
Precond Factoring MFLOP Rate : 1054.40 MFlops
2012年10月23日
ANSYSUser1999
你的"shitanxi001.PCS" 文件(file)的内容是什么?
2012年10月23日
