ansys 14能安装在其它盘吗,
浏览:51852 回答:4
在安装ansys14时,我不想安装C盘,C盘没有空间了,有没有办法安装在D盘呢。
(4)
lengxuef
Installation Directory:
d:\Program Files\ANSYS Inc
Windows x64
ANSYS, Inc. Products
ANSYS Structural Mechanics
ANSYS Mechanical Products
ANSYS Explicit Dynamics
ANSYS AUTODYN
ANSYS LS-DYNA
ANSYS Fluid Dynamics
ANSYS CFX (includes ANSYS CFD-Post)
ANSYS FLUENT (includes ANSYS CFD-Post)
ANSYS TurboGrid
ANSYS POLYFLOW (includes ANSYS CFD-Post)
ANSYS Offshore
ANSYS AQWA
ANSYS Additional Tools
ANSYS ICEM CFD
ANSYS ICEM CFD Creo Parametric (formerly Pro/ENGINEER) Interface
ANSYS ICEM CFD NX Interface
ANSYS Icepak (includes ANSYS CFD-Post)
ANSYS Geometry Interfaces
AutoCAD
ACIS
Catia, Version 4
Catia, Version 5
Creo Elements/Direct Modeling
Inventor
JTOpen
NX
Parasolid
Solid Edge
SolidWorks
Installing MS VC++ 2005 SP1 Redistributable x64
Everything was successfully installed.
The installation will copy the prerequisite setup files from the media in case you need to reconfigure later or if you need to configure client machines for products installed to a network share.
This may take a while ...
Successfully copied prerequisites from media.
2012年12月4日
lengxuef
没问题,许可证装C盘,软件装D盘
这是我的安装日志文件。
C:\Program Files\ANSYS Inc
Windows x64
ANSYS, Inc. License Manager
Reading the installation media contents - please wait.
Extraction: J:\instcore\tcl\COMMON.TGZ ...
Extraction: J:\instcore\tcl\WINX64.TGZ ...
Extraction: J:\licserv\WINX64.TGZ ...
Extraction: J:\license\WINX64.TGZ ...
Extraction: J:\hlp\hlplic\HLPLIC.TGZ ...
Running C:\Program Files\ANSYS Inc\Shared Files\Licensing\winx64\APLConfig.exe /s
Performing licensing configuration via the following command...
"C:\Program Files\ANSYS Inc\Shared Files\bin\win32\wish.exe" "C:\Program Files\ANSYS Inc\Shared Files\Licensing\licadmin\scripts\LicAdminMain.itcl" -installserver140 -defaultlocale en-us
Licensing configuration has completed.
Installation Complete. Please review the above information.
2012年12月4日
2506517320
安装ansys14主要文件时可以更改到D盘,但是安装license文件时,就不能把安装的路径更改了,
不知道你有没有试装过?
2012年12月3日
lengxuef
可以,路径设置到D盘就行了。
2012年12月3日
