abaqus6.10子程序通不过呀
浏览:26145 回答:5
按照网上的步骤安装的,装了两天了,一直通不过呀。为什么?W7,32位的系统,安装的是 abaqus6.10+MVS2008+IVF10.1
Abaqus Product Install Verification...
Wed Jan 23 17:29:41 2013
Running system requirement checks.
Requirement: Windows Server 2003, Windows XP, Windows Vista, or Windows 7
Product: All Abaqus Products
Status: Pass - Found Windows 7 Ultimate (Build 7600) (x86).
Requirement: Microsoft Visual C++ 9.0 (2008), or 10.0 (2010)
Product: Abaqus make utility with C++
Status: Pass - Found Microsoft Visual C++ 9.0.21022.8.
Requirement: Intel Fortran Compiler 10.1 or 11.1
Product: Abaqus make utility with Fortran and Abaqus with user
subroutines
Status: Pass - Found Intel Fortran Compiler 10.1 Build 20100611
Package ID w_fc_p_10.1.034.
Requirement: HP-MPI 01.01.00.00
Product: Abaqus analyses using MPI-based parallelization and
Abaqus/CFD
Status: Pass - Found HP-MPI 01.01.00.00.
Requirement: Internet Explorer 6.0 or 7.0 or 8.0, Firefox 2.0 or 3.0 or
3.5, or greater
Product: Abaqus Documentation
Status: Fail - Found 360安全浏览器 5.0.9.6.
Found E:\Temp\verify. All verification files will reside in this directory.
Old job files exist. They will be moved to verifyOLD.
Abaqus/Standard
...PASS
Continuing...
Abaqus/Standard with user subroutines
...ERROR
Abaqus did not complete successfully.
Please see std_user.log for details.
Continuing...
Abaqus/Explicit (single precision)
...PASS
Continuing...
Abaqus/Explicit (double precision)
...PASS
Continuing...
Abaqus/Explicit with user subroutines (single precision)
...ERROR
Please see xpl_user_sp.log for details.
Continuing...
Abaqus/Explicit with user subroutines (double precision)
...ERROR
Please see xpl_user_dp.log for details.
Continuing...
Abaqus/Viewer
...PASS
Continuing...
Abaqus/CAE
...PASS
Continuing...
Geometry Translator for CATIA V4
...PASS
Continuing...
Geometry Translator for CATIA V5
...PASS
Continuing...
Direct Geometry Import for CATIA V5
...PASS
Continuing...
Geometry Translator for I-DEAS
...PASS
Continuing...
Geometry Translator for Parasolid
...PASS
Continuing...
Geometry Translator for Pro/ENGINEER
...PASS
Continuing...
SolidWorks Associative Interface
...PASS
Continuing...
Abaqus/AMS
...PASS
Continuing...
Abaqus Interface for MSC.ADAMS
...PASS
Continuing...
Abaqus/Standard parametric studies
...PASS
Continuing...
Abaqus/Explicit parametric studies
...PASS
Continuing...
Abaqus/Design
...PASS
Continuing...
Abaqus Interface for Moldflow
...PASS
Continuing...
...ERROR
Please see fortran_make.log for details.
Continuing...
...ERROR
Please see cpp_make.log for details.
Continuing...
Abaqus make utility with object code
...WARNING
Abaqus make utility with C++ failed. Verification
procedure will be skipped.
Continuing...
Abaqus scripting interface
...PASS
Continuing...
Abaqus analyses using parallelization
Running thread-based parallel with 2 cpu(s)
Abaqus/Explicit domain-level parallel
...PASS
Abaqus/Standard direct solver
...PASS
Continuing...
Abaqus/Foundation
...PASS
Continuing...
Abaqus noGUI (CAE/Viewer)
...PASS
Continuing...
Abaqus/CFD
...PASS
Continuing...
Clean-up...
Job files exist. Verification directory E:\Temp\verify will not be deleted.
FUMOZHOU
你好楼主,我这64位也和你一样的问题,求指教啊
2013年3月30日
assilen
楼主,请问子程序通不过的问题怎么解决的?我现在也遇到了和你一样的问题,求指教
2013年3月15日
Alisonhu
摸索了好几天,终于全通过了。YES。
2013年1月24日
评论 2 点赞
