网格划分
浏览:165138
我在做一个高层混凝土结构,为什么用下面两层建出来的几何模型可以网格划分,而用vgen复制十层后不能划分呢,弹出来的错误是Volume 9213 has invalid topology for mapped brick meshing.
/COM,ANSYS RELEASE 13.0 UP20101012 18:01:02 04/02/2013
*** ERROR *** CP = 307.057 TIME= 18:17:14
Mapped brick meshing is not possible in hexahedron volume 9213 because
areas 33567 and 33562 have an inconsistent reference to line 39140.
Please send the data leading to this operation to your technical
support provider, as this will allow ANSYS, Inc to improve the
program.
