热固耦合
浏览:129554
这是一个热固耦合的问题,有两种材料,一种是刚性材料,一种是弹塑性材料,预给弹塑性材料加载温度参数,发现加了之后总出现
CHECKING MATERIAL INPUT DATA Part ID= 1
*** Error part ID 1 with
section ID 1 and
THERMAL ID 1 does not exist.
This is part 1 in the order of input.
CHECKING MATERIAL INPUT DATA Part ID= 2
*** Error part ID 2 with
section ID 2 and
THERMAL ID 2 does not exist.
This is part 2 in the order of input.
CHECKING MATERIAL INPUT DATA Part ID= 3
*** Error part ID 3 with
section ID 3 and
THERMAL ID 3 does not exist.
This is part 3 in the order of input. CHECKING MATERIAL INPUT DATA Part ID= 4
*** Error part ID 4 with
section ID 4 and
THERMAL ID 4 does not exist.
This is part 4 in the order of input.
*** Error input data failed with: 6 errors
E r r o r t e r m i n a t i o n
Memory required for explicit solution : 1647122
Additional dynamically allocated memory: 30
Total: 1647152
请各位高手指点一二,k文件如下
$ SECTION DEFINITIONS $
*SECTION_SOLID
1 1
$ MATERIAL DEFINITIONS $
*MAT_RIGID
1 0.780E-05 207.0 0.330000 0.0 0.0 0.0
1.00 4.00 7.00
*MAT_JOHNSON_COOK
2 0.440E-05 50.8 132.0 0.300000 0.000000
1.17 0.590E-01 0.449 0.172E-01 1.20 0.161E+04 293.0 0.100E-02
612.0 -1.40 3.00 0.00-0.900E-01 0.270 0.480 0.140E-01
3.87
*EOS_GRUNEISEN
2 0.394E+04 1.49 0.00 0.00 2.15 0.455 0.00
1.00
*MAT_RIGID
3 0.780E-05 207.0 0.330000 0.0 0.0 0.0
1.00 4.00 7.00
*MAT_RIGID
4 0.780E-05 207.0 0.330000 0.0 0.0 0.0
1.00 4.00 7.00
*MAT_THERMAL_ISOTROPIC
2 0.440E-05
460.0 0.460E-05
*INITIAL_TEMPERATURE_SET
0 300.00000
*SET_NODE_LIST
0 0.0 0.0 0.0 0.0
0 2
*set_node_general
0
part,2
$ PARTS DEFINITIONS $
*PART
Part 1 for Mat 1 and Elem Type 1
1 1 1 0 0 0 0
*PART
Part 2 for Mat 2 and Elem Type 1
2 1 2 2 0 0 0
*PART
Part 3 for Mat 3 and Elem Type 1
3 1 3 0 0 0 0
*PART
Part 4 for Mat 4 and Elem Type 1
4 1 4 0 0 0 0
section ID 1 and
section ID 2 and
section ID 3 and
section ID 4 and
Total: 1647152
请各位高手指点一二,k文件如下
*SECTION_SOLID
1 1
*MAT_RIGID
1.00 4.00 7.00
*MAT_JOHNSON_COOK
3.87
*EOS_GRUNEISEN
1.00
*MAT_RIGID
1.00 4.00 7.00
*MAT_RIGID
1.00 4.00 7.00
2 0.440E-05
460.0 0.460E-05
0 300.00000
*SET_NODE_LIST
0 0.0 0.0 0.0 0.0
0 2
*set_node_general
0
part,2
*PART
1 1 1 0 0 0 0
*PART
2 1 2 2 0 0 0
*PART
3 1 3 0 0 0 0
*PART
4 1 4 0 0 0 0
