求教!!!请高手解惑,事情比较急我在用dynaform进行运算时,出现错误终止,但还是生成了D3plot文件
浏览:140818 回答:10
我在用dynaform进行运算时,出现错误终止,但还是生成了D3plot文件,在后处理中看不到成型过程,下面是messag文件 请高手指出错误,我该怎么解决 谢谢!!
Date: 04/15/2013 Time: 16:53:38
___________________________________________________
| Livermore Software Technology Corporation |
| 7374 Las Positas Road |
| Livermore, CA 94551 |
| Tel: (925) 449-2500 Fax: (925) 449-2507 |
| www.lstc.com |
|_________________________________________________|
| LS-DYNA, A Program for Nonlinear Dynamic |
| Analysis of Structures in Three Dimensions |
| Version : ls971s R3 beta Date: 09/24/2007 |
| Revision: 40176 Time: 15:10:10 |
| Features enabled in this version: |
| Interactive Graphics |
| Licensed to: |
| Platform : PC WIN32 |
| OS Level : WINDOWS XP |
| Compiler : Intel Fortran Compiler 9.1 |
| Hostname : clx054 |
| Precision : Single precision (I4R4) |
| Unauthorized use infringes LSTC copyrights |
Input file: C:\DOCUME~1\ADMINI~1\桌面\上板\df\shangban.dyn
The native file format : 32-bit small endian
Memory size from command line: 134217728
JOBID : shangban
expanding memory to 134217728 starting ls-dyna
******** notice ******** notice ******** notice ********
* This is the LS-DYNA Explicit Finite Element code. *
* Neither LSTC nor the authors assume any responsibility for *
* the validity, accuracy, or applicability of any results *
* obtained from this system. The user must verify his own *
* results. *
* LSTC endeavors to make the LS-DYNA code as complete, *
* accurate and easy to use as possible. *
* Suggestions and comments are welcomed. Please report any *
* errors encountered in either the documentation or results *
* immediately to LSTC through your site focus. *
* Copyright (C) 1990-2007 *
* by Livermore Software Technology Corp. (LSTC) *
* All rights reserved *
contracting memory to 1 beginning of keyword reader
expanding memory to 20160
expanding memory to 1035806
expanding memory to 1080806
expanding memory to 1110806
expanding memory to 3176690
expanding memory to 3348847
expanding memory to 4025978
expanding memory to 4698606
expanding memory to 4725208
Open include file: shangban.blk
Open include file: shangban.mod
expanding memory to 4897120
expanding memory to 5065325
expanding memory to 6915580
expanding memory to 7082737
expanding memory to 7249894
expanding memory to 7418099
expanding memory to 7919570
expanding memory to 8087775
expanding memory to 8254932
expanding memory to 14609304
expanding memory to 17628611
expanding memory to 17795768
expanding memory to 17963973
expanding memory to 18132178
Memory required to process keyword : 18132178
contracting memory to 1 end of keyword reader
LS-DYNA will perform a structural only analysis
SHANGBAN_PRACTICE
ls-dyna ls971s.40176 R3 date 09/24/2007
*** Warning reset D3PLOT output interval from 0. to 1.7695E-02
259604 259605 259606 260349
259495 259496 260350 260348
additional segments are being renumbered but not printed
slave surface has128751 segments, 28480 renumbered
The LS-DYNA time step size should not exceed 4.128E-05
to avoid contact instabilities. If the step size is
bigger then scale the penalty of the offending surface.
s t o r a g e a l l o c a t i o n
Memory required to begin solution : 41490345
Additional dynamically allocated memory: 1555892
Total: 43046237
Slave side interface # 1
# nodes on + segment side = 2 max dist = 3.76623E+01 min dist = 3.61808E+01
# nodes on - segment side = 1398 max dist = 2.69991E+01 min dist = 9.29476E+00
*** Warning slave nodes may cross the surface
please check your model, job continues
Master side interface # 1
# nodes on + segment side = 0 max dist =-1.00000E+10 min dist = 1.00000E+10
# nodes on - segment side = 65 max dist = 2.54338E+01 min dist = 9.00050E+00
Slave side interface # 2
# nodes on + segment side = 109 max dist = 3.45806E+01 min dist = 8.42150E+00
# nodes on - segment side = 0 max dist =-1.00000E+10 min dist = 1.00000E+10
Master side interface # 2
# nodes on + segment side = 11 max dist = 2.45123E+01 min dist = 9.87941E+00
calculation with mass scaling for minimum dt
added mass = 3.5233E-03
physical mass= 2.0202E+00
ratio = 1.7440E-03
1 t 0.0000E+00 dt 1.08E-06 flush i/o buffers
1 t 0.0000E+00 dt 1.08E-06 write d3plot file
*** WARNING plasticity algorithm did not converge for MAT36
for 1 elements
for 1 elements
for 1 elements
for 1 elements
node # 1 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 2 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 3 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 4 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 5 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 6 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 7 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 8 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 9 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 10 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 11 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 12 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 13 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 14 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 15 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 16 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 17 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 18 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 19 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 20 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 21 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 22 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 23 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 24 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 25 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 26 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 27 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 28 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 29 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 30 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
458 t 4.9356E-04 dt 1.08E-06 write d3plot file
E r r o r t e r m i n a t i o n
Memory required to complete solution : 41490345
Total: 43046237
T i m i n g i n f o r m a t i o n
CPU(seconds) %CPU Clock(seconds) %Clock
Initialization ....... 0.0000E+00 0.00 0.0000E+00 0.00
Element processing ... 4.9600E+02 75.15 4.9316E+02 74.77
Binary databases ..... 0.0000E+00 0.00 3.5900E-01 0.05
ASCII database ....... 0.0000E+00 0.00 0.0000E+00 0.00
Contact algorithm .... 1.6400E+02 24.85 1.6605E+02 25.17
Contact entities ..... 0.0000E+00 0.00 0.0000E+00 0.00
Rigid bodies ......... 0.0000E+00 0.00 3.1000E-02 0.00
Implicit Nonlinear ... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Lin. Alg. ... 0.0000E+00 0.00 0.0000E+00 0.00
T o t a l s 6.6000E+02 100.00 6.5961E+02 100.00
Problem time = 4.9356E-04
Problem cycle = 458
Total CPU time = 660 seconds ( 0 hours 11 minutes 0 seconds)
CPU time per zone cycle = 8620 nanoseconds
Clock time per zone cycle= 8615 nanoseconds
Number of CPU's 1
NLQ used/max 96/ 96
Start time 04/15/2013 16:53:38
End time 04/15/2013 17:04:44
Elapsed time 666 seconds( 0 hours 11 min. 6 sec.) for 458 cycles
| www.lstc.com |
| Licensed to: |
| Hostname : clx054 |
JOBID : shangban
* results. *
SHANGBAN_PRACTICE
Total: 43046237
ratio = 1.7440E-03
for 1 elements
for 1 elements
for 1 elements
for 1 elements
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
Total: 43046237
Problem cycle = 458
Number of CPU's 1
NLQ used/max 96/ 96
2你的设置估计有问题,这个需要你上传前处理,进行分析了,光看message看不出来;
