帮我怎么解决abaqus切削中的错误
浏览:140609 回答:1
Error in job Job-1: Thermal contact has been defined between the surfaces ASSEMBLY_TOOL-FACE and ASSEMBLY_CHIP-BOT, but no temperature degrees of freedom associated with the surface ASSEMBLY_TOOL-FACE.
Job Job-1: Abaqus/Explicit Packager aborted due to errors.
迷途的小狗
没有定义初始温度吧
2018年4月24日
