unmeshed line 34 is merged into meshed line 27什么意思,怎么解决的?
浏览:51077 回答:1
/clear
/prep7
et,1,solid45
et,2,mesh200,6
!土体材料参数
mp,ex,1,3.49e6
mp,prxy,1,0.35
mp,dens,1,1828
mp,ex,2,20.6e6
mp,prxy,2,0.30
mp,dens,2,2160
mp,ex,3,500e6
mp,prxy,3,0.33
mp,dens,2,2160
!管片材料参数,管片衬砌按各向同性计算
mp,ex,4,27.6e9
mp,prxy,4,0.2
mp,dens,4,2500
!注浆层,参数按水泥土取值
mp,ex,5,1e9
mp,prxy,5,0.2
mp,dens,5,2100
!在隧道中心线定义局部坐标,便于后面的实体选取
local,11,0,0,0,0
local,12,1,0,0,0
csys,11
wpcsys,-1
cyl4,,,,,2.7,90
cyl4,0,0,2.7,0,3,90
cyl4,0,0,3,0,3.2,90
rectng,0,4.5,0,4.5
aovlap,all
nummrg,all
numcmp,all
rectng,4.5,31.5,0,4.5
nummrg,all
numcmp,all
mshkey,1
type,2
lesize,1,,,6
lesize,2,,,6
lesize,3,,,6
amesh,1
lesize,4,,,6
lesize,8,,,2
lesize,9,,,2
amesh,2
lesize,5,,,6
lesize,10,,,1
lesize,11,,,1
amesh,3
lesize,12,,,3
lesize,13,,,3
lesize,6,,,3
lesize,7,,,3
lesize,14,,,8,2
lesize,16,,,8,0.5
amap,4,7,6,8,10
amap,5,9,8,11,12
!利用对称性,得到下半部分模型
arsym,y,all
nummrg,all
numcmp,all
allsel,all
!建立隧道下方土层模型
rectng,0,4.5,-4.5,-26
rectng,4.5,31.5,-4.5,-26
nummrg,all
前面的没问题的 一但输入 最后一行的nummrg,all就提示
unmeshed line 34 is merged into meshed line 27.
请教ansys高手解答。。。 谢谢
/prep7
et,1,solid45
et,2,mesh200,6
!土体材料参数
mp,ex,1,3.49e6
mp,prxy,1,0.35
mp,dens,1,1828
mp,ex,2,20.6e6
mp,prxy,2,0.30
mp,dens,2,2160
mp,ex,3,500e6
mp,prxy,3,0.33
mp,dens,2,2160
!管片材料参数,管片衬砌按各向同性计算
mp,ex,4,27.6e9
mp,prxy,4,0.2
mp,dens,4,2500
!注浆层,参数按水泥土取值
mp,ex,5,1e9
mp,prxy,5,0.2
mp,dens,5,2100
local,11,0,0,0,0
local,12,1,0,0,0
csys,11
wpcsys,-1
cyl4,,,,,2.7,90
cyl4,0,0,2.7,0,3,90
cyl4,0,0,3,0,3.2,90
rectng,0,4.5,0,4.5
aovlap,all
nummrg,all
numcmp,all
nummrg,all
numcmp,all
mshkey,1
type,2
lesize,1,,,6
lesize,2,,,6
lesize,3,,,6
amesh,1
lesize,4,,,6
lesize,8,,,2
lesize,9,,,2
amesh,2
lesize,5,,,6
lesize,10,,,1
lesize,11,,,1
amesh,3
lesize,12,,,3
lesize,13,,,3
lesize,6,,,3
lesize,7,,,3
lesize,14,,,8,2
lesize,16,,,8,0.5
amap,4,7,6,8,10
amap,5,9,8,11,12
!利用对称性,得到下半部分模型
arsym,y,all
nummrg,all
numcmp,all
allsel,all
!建立隧道下方土层模型
nummrg,all
请教ansys高手解答。。。 谢谢
在这段命令流中,隧道下方土层模型与上方模型的交界位置有两条线重合(编号分别为30-24、34-27),因此在使用numcmp,all这个命令的时候会出现"Unmeshed line 30 is merged into meshed line 24"、“Unmeshed line 34 is merged into meshed line 27”这两个警告窗口。一般这种警告直接忽视就可以了。
