abaqus运行过程中电脑蓝屏
浏览:132103 回答:5
我是一个新手,请问大家一下,用abaqus进行齿轮接触分析,运行过程中电脑蓝屏是什么原因呢?
(5)
newuser
因为在计算机上运行时间很久后就蓝屏了,而且在不同的计算机上都出现过同样的问题,所以我自己觉得可能是接触不收敛的问题,现在在监控器中出现如下的警告信息,我不知道如何进行更改,大侠们都帮我分析分析吧!“The nodes in node set WarnNodeMassAugment-Step1 areinvolved in constraints that have to be solved using the implicit solver. The nodes involved in these constraints have masses that are highly mismatched, hence the implicit solver may encounter convergence problems. To prevent this from happening the masses of the nodes in this set have been augmented by a small amount. The additional mass will almost never affect the solution significantly except for strongly dynamic analyses.
The nodes in node set WarnNodeInertiaAugment-Step1 areinvolved in constraints that have to be solved using the implicit solver. The nodes involved in these constraints have rotary inertia that are highly mismatched, hence the implicit solver may encounter convergence problems. To prevent this from happening the rotary inertias of the nodes in this set have been augmented by a small amount. The additional rotary inertia will almost never affect the solution significantly except for strongly dynamic analyses.”
2013年8月23日
newuser
应该不是内存的原因,因为我是在工作站上运行的
2013年8月23日
kays
是不是内存不够,或者硬盘空间不够,导致系统崩溃。 或者其他原因
2013年8月22日
fengpning
蓝屏?可能是系统问题,也可能是你显卡不行
2013年8月21日
谢清乐
蓝屏,电脑系统问题,哈哈。
2013年8月20日
