求教 关于adams中约束出现WARNING的问题
浏览:124430 回答:1
WARNING: The distance from the origin of the J marker
to the Z-axis of the I marker is 0.2375096364
(No warnings if less than +/-1.0E-003)
Cylindrical Joint = .model_1.JOINT_25
I Marker = .model_1.PART4_flex.MARKER_156
J Marker = .model_1.PART2_flex.MARKER_157
WARNING: The I marker of model_1.JOINT_25 is not on the
z-axis of the J marker. The relative displacement from
the z-axis, expressed in the J marker coordinate frame is:
Delta X = -0.0006 Delta Y = -0.2375.
求大神给个明路啊 愁死了
zhaols2068
来个人回答一下
2013年8月26日
