官网上的解释: Altair HyperGraph is a powerful data analysis and plotting tool with interfaces to many popular file formats. Its sophisticated math engine is capable of processing even the most complex mathematical expressions. HyperGraph combines these features with high-quality presentation output and customization capabilities to create a complete data analysis system for any organization. Altair HyperView is a complete post-processing and visualization environment for finite element analysis (FEA), multi-body system simulation, video, and engineering data. Amazingly fast 3-D graphics and unparalleled functionality set a new standard for the speed and integration of CAE results post-processing. HyperView enables you to visualize data interactively as well as capture and standardize your post-processing activities using process automation features. HyperView also saves 3-D animation results in Altair's compact H3D format so you can visualize and share CAE results within a 3-D web environment using Altair HyperView Player.
hypergragh主要是线图,比如某点的加速度响应,输出的是一个频率加速度曲线。用这个可以看到结果
hyperview则主要是拓扑云图。你要看整体的应力啊位移啊应变和温度等等都是用这个。
两个其实是有本质区别的
