用LS-DYNA做地震分析,出现错误
浏览:186255
[p=143, null, left]http://www.caenet.cn[/p]
*** Error repeated points in load curve number= 1 point number= 2
*** Error load curve 1 has vertical slope
Check that this curve is correct
*** Error repeated points in load curve number= 2 point number= 2
*** Error load curve 2 has vertical slope
Memory required for explicit solution : 401081
Additional dynamically allocated memory: 10128
Total: 411209
我是在外荷载作用下,加地震波求解是出现的
