Dynaform5.8.1一提交任务就aborted是什么原因?应用手册第一个例子做了N遍了,还是不好使??
浏览:125430 回答:3
按照使用手册设置完之后,提交任务,然后没算几秒就aborted,下面贴出messag文件里的错误信息,求大神给指条明路!!另外谁有可以用的版本,求发一个啊,这两天已经下了6/7/8了,都不好使,快疯了,求解救啊,留个邮箱302796960@qq.com,我也知道伸手党可耻,但真的是没办法了,如果帖子里有什么违反论坛规矩的,还请多包涵!
Date: 04/29/2014 Time: 16:55:58
___________________________________________________
| Livermore Software Technology Corporation |
| 7374 Las Positas Road |
| Livermore, CA 94551 |
| Tel: (925) 449-2500 Fax: (925) 449-2507 |
| www.lstc.com |
|_________________________________________________|
| LS-DYNA, A Program for Nonlinear Dynamic |
| Analysis of Structures in Three Dimensions |
| Version : ls971d R5.0 Date: 04/10/2010 |
| Revision: 59419 Time: 10:11:54 |
| Features enabled in this version: |
| Shared Memory Parallel |
| ANSYS Database format |
| 32 Bit IEEE Binary File |
| Licensed to: |
| Platform : WIN32 |
| OS Level : Home Edition (Build 7600)3/2008 |
| Compiler : Intel Fortran Compiler 10.1 |
| Hostname : xz |
| Precision : Double precision (I8R8) |
| SVN Version: 59824 |
| Unauthorized use infringes LSTC copyrights |
Input file: C:/Users/xz/Desktop/Dynaform/新建文~1/APPLIC~1/case1/FENDER~1.DYN
The native file format : 64-bit small endian
Memory size from command line: 131072000
JOBID : fender_op05
Memory option : AUTO selected
expanding memory to 131072000 starting ls-dyna
******** notice ******** notice ******** notice ********
* This is the LS-DYNA Finite Element code. *
* Neither LSTC nor the authors assume any responsibility for *
* the validity, accuracy, or applicability of any results *
* obtained from this system. The user must verify his own *
* results. *
* LSTC endeavors to make the LS-DYNA code as complete, *
* accurate and easy to use as possible. *
* Suggestions and comments are welcomed. Please report any *
* errors encountered in either the documentation or results *
* immediately to LSTC through your site focus. *
* Copyright (C) 1990-2010 *
* by Livermore Software Technology Corp. (LSTC) *
* All rights reserved *
contracting memory to 1 beginning of keyword reader
expanding memory to 22120
expanding memory to 122270
expanding memory to 167270
expanding memory to 197270
expanding memory to 445790
expanding memory to 466500
expanding memory to 489273
expanding memory to 556113
expanding memory to 622953
expanding memory to 644663
expanding memory to 666165
expanding memory to 686165
expanding memory to 706165
expanding memory to 726165
expanding memory to 750527
Open include file: fender.blk
Open include file: fender_op05.mod
expanding memory to 774627
expanding memory to 952180
expanding memory to 983600
expanding memory to 1045443
Memory required to process keyword : 1045443
contracting memory to 1 end of keyword reader
LS-DYNA will perform a structural only analysis
gravity / untitled
ls-dyna ls971d.59419 R5.0 date 04/10/2010
| www.lstc.com |
| Licensed to: |
| Platform : WIN32 |
| Hostname : xz |
JOBID : fender_op05
* results. *
gravity / untitled
