- 技术邻 >
- CAE仿真 >
- HyperWorks
用optistruct做分析时候出现的警告,然后再hyperview看不到效果图是怎么回事
浏览:63013 回答:9
Messages for the job:
*** WARNING # 312
In static load case 1
the compliance is negative or large 5.968586E+10
Optimization/buckling analysis cannot be performed
due to possible rigid body mode
*** WARNING # 312
In static load case 2
the compliance is negative or large 1.658063E+13
*** WARNING # 312
In static load case 5
the compliance is negative or large 1.664343E+13
ANALYSIS COMPLETED.
*** WARNING # 312
*** WARNING # 312
*** WARNING # 312
ANALYSIS COMPLETED.
约束问题,比如刚性连接出错,节点没选上等等
