安装6.13版本,测试完美运行 1. Run "Install Abagus Product & Licensing" 2. In SIMULIA FLEXnet License Server window select "Just install the license utilities" NOTE: If you already have SIMULIA FLEXnet License Server for ABAQUS 6.12-3 installed and running you can use it for 6.13-1 too 3. After finishing License Utilities setup copy files "ABAQUS.lic" and "ABAQUS.log" to <SIMULIA FLEXnet License Server progdir> (by default C:\SIMULIA\License\) 4. Configure and run SIMULIA FLEXnet License Server as service 4.1. Run lmtools.exe 4.2. On "Servise/License File" tab select "Configuration using Services" 4.3. On "Config Service" tab input the new Service Name (for example: SIMULIA FLEXnet License Server) 4.4. Browse to "lmgrd.exe", "ABAQUS.lic" and "ABAQUS.log" files 4.5. Select "Use Service" and "Start Server at Power Up", click "Save Service" 4.6. On "Start/Stop/ReRead" tab click "Start Server" 4.7. Close lmtools do not pay attention warning the license file you have selected is not valid for this machine? continue 5. For ABAQUS "Installation type" window select "SIMULIA FLEXnet License Server" 6. In "License Server" window input for "License server1 (REQUIRED)" 27011@<computername> there <computername> mast be the name of computer with SIMULIA FLEXnet License Server server installed 7. Continue and finish setup 8. Enjoy Cracked by TEAM-SolidSQUAD (SSQ)
